How To Connect Red, White, And Black Wire. - Electrical - DIY Chatroom Home Improvement Forum
Old 09-02-2012, 08:35 AM   #1
how to connect red, white, and black wire.
i am upgrading this older home. it had an old oven with red, white and balck wire coming from grey , black and red wire. i am trying to install an outlet for a microwavw any ideas please.
fred450 is offline   Reply With Quote
Old 09-02-2012, 08:37 AM   #2
how to connect red, wite, and black wire.
frelance450 is offline   Reply With Quote
Old 09-02-2012, 09:01 AM   #3
DIY staff
Rewards Points: 7,174
I merged these two together---funny that two new members would have the exact same issue on the same day---
Have you tested the circuit? Sounds like a 220 line---what did your tester tell you? What kind of breaker controls that circuit?
Old 09-02-2012, 09:14 AM   #4
Rewards Points: 1,448
Which set of wires (red/white/black versus gray/black/red) comes from the oven and which set comes out of the wall?
You can connect up an ordinary 120 volt receptacle or receptacle pair to the red and white or to the black and white provided you have 120 volts across those two and the breaker for that circuit is for no more than 20 amperes.
You want a voltmeter or multimeter, not a circuit tester or test light.
Old 09-02-2012, 09:38 AM   #5
Thanks for the response. the wires that come out of the wall are grey, black , and red, the wires that came out of the old model oven were white, black, and red. I am trying to connect it and an outlet for microwave oven. Also how much voltage, 110 or 220. a microwave oven needs. I do not have a tester sorry.
Old 09-02-2012, 10:24 AM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Does the cable also have a bare copper wire?
Coastal South Carolina
Old 09-02-2012, 10:34 AM   #7
outlet type
I have an older home with white, red, and back wires in the kitchen that came off a double story oven. What type of ouitlet do I need to create an outlet for over ranger microwave. The existing Do I need to cap off the red and what type of outlet would handle this?
Old 09-02-2012, 10:45 AM   #8
the Musigician
DangerMouse's Avatar
Not if they're the same person it's not.
Check the IP....
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
AtlanticWBConst. (09-02-2012)
Old 09-02-2012, 10:46 AM   #9
Pure Genius
Rewards Points: 150
What breaker controls this? Is it a double pole breaker? If so i would cap the red wire. Install a single pole breaker in your panel and install a regular duplex receptacle. As long as your wire size is ok just install a 20 a breaker
Dierte is offline   Reply With Quote
Old 09-02-2012, 10:46 AM   #10
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
It would be in your health interests to have a voltage tester...you can't just guess and we just can't take your word for it ....
Are you wanting to connect to the oven branch circuit to serve the microwave receptacle ?
No offense but to ask us how much voltage a microwave needs when it is cord and plug tells me that you may want to seek someone who has some experience with residential appliance installations.
Old 09-02-2012, 10:50 AM   #11
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,878
I'm sorry. Thee is NO WAY you should be messing with this.
You are trying to connect a receptacle for a microwave, to an oven circuit, you don't know the voltage, and you don't even have a tester??? Should I even bring up the subject of amperage?
PLEASE just hire an electrician so no one gets hurt.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
DangerMouse (09-02-2012), frenchelectrican (09-02-2012)
Old 09-02-2012, 10:51 AM   #12
UAW SKILLED TRADES
Stubbie's Avatar
You need to stop making multiple posts about the same thing ...
Reply to the original post you made and begin by answering the questions we are asking you ....
Old 09-02-2012, 10:57 AM   #13
An old Tradesmen
Rewards Points: 6,544
Merged the third thread also.
Old 09-02-2012, 11:36 AM   #14
A "Handy Husband"
rjniles's Avatar
We are most likely being deked. I think we need to stop responding until the poster answers the questions.
Old 09-02-2012, 11:44 AM   #15
Master Electrician
Rewards Points: 3,760
Is the "gray" wire insulated or a bare conductor?
brric is offline   Reply With Quote
Two black wires and two white wires in a ceiling mshaw11 Electrical 6 07-11-2012 10:57 PM
ceiling fan wicked97 Electrical 4 08-21-2011 09:12 AM
Outlet With Swith and Older (White, Black, Red) Wire CaptChaos Electrical 18 09-15-2009 12:17 AM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 02:00 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
