Old 06-01-2011, 09:27 AM   #1
How to connect a day night switch to the lights
How is the day night switch connected to the lights. What I know is the wires will always have power but the switch is the one that regulates the flow of electricity to pass or not to pass to the lights.
Gibbs is offline   Reply With Quote
Old 06-01-2011, 12:31 PM   #2
DIY'er
jamiedolan's Avatar
Should be the same as any other switch, you should only have to run the hot to it and switch the hot (you only ever switch the hot). Some switches can require a neutral, but that is normally only if they have a light on them. I don't think a dawn/dusk needs a neutral, It should be obvious if it does.
Source (Neutral) >> >> (Lights)
Source (Ground) >> (Switch*) >> (Lights)
Source (Hot) >> (Switch) >> (Lights)
*Connected on the green ground screw and bonded to the box if it is metal.
Jamie Dolan - Neenah, WI
Need Help Uploading Photos?
jamiedolan is offline   Reply With Quote
How to connect 2 lights to a double switch B4rg Electrical 7 05-09-2011 10:18 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
2 lights 1 switch lymantuttle Electrical 10 01-04-2010 06:49 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
installed recessed lights but now switch does not work auggie77 Electrical 2 08-02-2009 11:11 AM
