How To Connect Bath Fan To Existing Light? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-11-2013, 03:12 PM   #1
Rewards Points: 452
How to connect bath fan to existing light?
I want bathroom exhaust fan to tap into existing light wiring so they both turn on together.
switch >> light >> fan
I haven't been up in the attic, but I think the wiring goes over, then down behind the wall to reach the wall light.
How do I tap into this wire? Do I have to cut it somewhere and then add pigtails?
More importantly, will this affect the voltage of the light and fan, and cause dimming or lower fan speed?
(not my bathroom....)
pman6 is offline   Reply With Quote
Old 04-11-2013, 03:49 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 142
Depending on how the power reaches the switch.
Remove the light fixture and connect the fan wires the same way the light fixture is wired.
The Following User Says Thank You to jbfan For This Useful Post:
pman6 (04-11-2013)
Old 04-11-2013, 07:33 PM   #3
Rewards Points: 452
I'm looking at a bath fan that has its own light.
The instructions assume you have a fancy multicontrol switch, which I won't have, since I'm connecting the fan to the vanity light.
it has a separate wire for the light and fan, and I'm going to disable the night light feature.
I can twist the blue and black fan wires together and pigtail them off the single incoming black wire so they operate together.... same idea right?
ceiling fan and light kit replacing existing light fixture libertyworks Electrical 8 10-23-2012 03:02 PM
5 Watt A15 light bulbs for bath Metallo Appliances 2 01-22-2011 09:54 PM
can i use my existing 120 v or do i need 240 for this light dcjcdc Electrical 1 08-22-2010 10:02 AM
Adding second light switch to an existing light TexasEd Electrical 7 08-15-2008 07:22 PM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 08:11 PM
