How To Connect 8 #14 Conductors Together? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-09-2011, 09:48 AM   #1
How to connect 8 #14 conductors together?
I'm working on the electrical for a hydronic heating system and the wiring for all the pumps and controls come back to one 4-3/4" square junction box. At the moment (as installed and inspected), there are 7 #14 neutrals connected by one large red wire nut. I need to add an 8th neutral to this bunch for a relay control.
Per the wire nut specs (from Ideal), they're rated for a max of 6 #14 wires.
What's the best (code compliant) method to do this?
Thanks!
belias is offline   Reply With Quote
Old 09-09-2011, 10:31 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
Twist 4 wires in one bundle, 4 wires in another bundle, run a short pigtail between the 2 bundles and add 2 wire nuts. That gives you 5 wires under each wire nut.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 09-09-2011, 11:19 AM   #3
Code05's Avatar
Rewards Points: 1,104
I am not a fan of these, but they are an option.
Wagos
Code05 is offline   Reply With Quote
Old 09-09-2011, 01:49 PM   #4
That was my first thought - any idea if this is permissible by the NEC?
Thanks,
- Brian
Old 09-09-2011, 01:53 PM   #5
A "Handy Husband"
rjniles's Avatar
Thanks,
- Brian
As long as the box is large enough for the number of conductors.
Old 09-09-2011, 04:16 PM   #6
Electrician
Rewards Points: 760
Get a bigger marette
darren is offline   Reply With Quote
Old 09-09-2011, 04:59 PM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Why not do it right and get a bigger wire nut as Darren said.
Old 09-09-2011, 05:14 PM   #8
I didn't think any wire nuts were listed for 8 #14 conductors - any idea which manufacturer it is?
Thanks.
Old 09-09-2011, 05:23 PM   #9
All of them. Look for big greys or big blues.
Old 09-09-2011, 05:38 PM   #10
As I read the specs, the largest wire nut made by Ideal can handle 6 #14's; the largest wire nut made by 3M can handle 7 #14's. What am I missing?
http://multimedia.3m.com/mws/mediawe...12111272_A.pdf
http://www.idealindustries.com/media...mbinations.pdf
Old 09-09-2011, 06:33 PM   #11
Licensed electrician
Rewards Points: 1,028
I checked the Ideal B4. It can only take 6 #14s. Seems kind of small when 5 #12s can fit in a B2.
Old 09-09-2011, 08:25 PM   #12
Found a catalog for wire connectors by Ideal. Page 20 has a chart for quick reference.
http://www.idealindustries.com/media...or_catalog.pdf
asfyxation is offline   Reply With Quote
Confusion over how many conductors in an electrical box dharper Electrical 11 07-08-2011 08:43 AM
Sizing Motor Branch Circuit Conductors and OCPD's electures Electrical 5 06-23-2011 12:32 AM
Marking buried cable a7ecorsair Electrical 15 07-20-2010 01:27 AM
non current carrying conductors davidbp Electrical 14 05-09-2010 11:09 PM
12-2 wire that is actualy 14-2 Mike Dolton Electrical 96 04-22-2010 02:07 PM
