How To Conceal 12-2 Wire Coming From Wall? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-20-2012, 05:53 PM   #1
How to conceal 12-2 wire coming from wall?
I recently removed a electric heater in the entry way of my condo. The heater was powered by a 12-2 about three inches from the floor.
There is no gang-box at all, and the wall is shared with the next condo, so I'm not sure what's inside the wall.
I'm basically trying to find a way to conceal the wires so it's not such a eye sore when people come in the house. I would like it to be the most visually attractive as possible.
Also when I switched the breaker off, there were two breakers connected together that controled this heater. Does that mean this had 240 volts going to it?
Also, how hard is it to install a gangbox?
Kid Quick is offline   Reply With Quote
Old 02-20-2012, 06:15 PM   #2
Mad Scientist
Was that the only thing on the circuit? If so, you can disconnect the wire from the breaker, and then you'd be okay to just push the exposed wire back into the wall and patch over it.
And yes, if it was connected to a double-pole breaker, it was a 240v heater.
McSteve is offline   Reply With Quote
The Following User Says Thank You to McSteve For This Useful Post:
Kid Quick (02-21-2012)
Old 02-20-2012, 06:17 PM   #3
as seen on tv
Rewards Points: 150
You could install an old work bx, replace the breaker and make it a receptacle. You could also install a wire mold box with a blank plate and disconnect breaker.
qbert is offline   Reply With Quote
The Following User Says Thank You to qbert For This Useful Post:
Old 02-20-2012, 06:19 PM   #4
Mad Scientist
The old work/remodel box was going to be my other suggestion as well, but since it's a common wall it's probably a fire-rated assembly, and I'm not sure cut-in boxes can be used.
Old 02-20-2012, 06:29 PM   #5
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Imstall old work box with a cover plate. And cap the wire mark wire in breaker box and on box cover in case someone wonders what it goes to in the future.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
The Following User Says Thank You to rrolleston For This Useful Post:
Old 02-20-2012, 06:29 PM   #6
I like this idea. It was the only item on the circuit. How would I disconnect the wire from the breaker? Is this a simple process?
Old 02-20-2012, 06:33 PM   #7
Mad Scientist
Simple enough; just turn off the breaker, remove the panel cover, and remove both wires from the breaker. Cap them with wire nuts, and tuck them out of the way somewhere. Label them so that in the future people will know where they used to go.
It's safer to turn off the main breaker as well.
Old 02-20-2012, 06:36 PM   #8
This is what I was going to suggest, too. Just take it off the breaker (mark it if you like, for future reference, or remove it from the panel completely) and then cut off the wire in question (check for voltage just to make sure its dead) and shove it into the wall/floor.
If you feel comfortable doing this, then open up your panel. If you like, you can shut off main power to be completely safe. Then just unscrew the wires from underneath the breaker. You can either cap them off in the panel (I suggest marking them for possible future reference), or taking the wire completely out of the panel and cutting it off somewhere.
hawkeye11 is offline   Reply With Quote
The Following User Says Thank You to hawkeye11 For This Useful Post:
Old 02-20-2012, 07:10 PM   #9
rrolleston's Avatar
I like to label them and leave them capped off. Never know when you could use them.
Old 02-20-2012, 07:53 PM   #10
OK,l I removed the panel and i now see this. Do I just unscrew the screws holding the black and white wires marked A and B? and just cap them off and I'm good? Any unobvious dangers I should be looking out for?
I assuming it wouldnt hurt to trip the breakers on the right hand side above and below where I"m going to be unscrewing the two screws?
Uploaded with ImageShack.us
Old 02-20-2012, 08:00 PM   #11
Yes, just unscrew the black and white indicated (assuming you're 100% sure its the correct breaker controlling the wire in question), and cap them off with and stick them into the side of the panel out of the way (again, I would mark it with a small note, indicating what this wire was originally used for, for future reference). And yes, you can turn off the breakers above and below if you it makes you feel more comfortable working.
Old 02-20-2012, 09:00 PM   #12
If I were you I would check how all your circuits are connected to the breakers, from what I can see in your pic, the hots going to the breakers are not installed properly. Looks like they are only catching by the screw heads! They should be under the u-shaped plate on the breakers , not under just the screw head! Could be wrong but looks like A B and all the others could slip right out from under the screw heads.
Amazingglazier is offline   Reply With Quote
The Following User Says Thank You to Amazingglazier For This Useful Post:
Old 02-20-2012, 10:22 PM   #13
Love for Construction
<*(((><'s Avatar
Edit: missed the picture, you have a subpanel, you can cut power to the whole sub including the feeders at the main.
-luke-
<*(((>< is offline   Reply With Quote
The Following User Says Thank You to <*(((>< For This Useful Post:
Old 02-20-2012, 11:34 PM   #14
rrolleston's Avatar
That looks like a sub panel with no main breaker. It's wired with 4 wire a separate neutral and ground. There is no way to turn off the main power.
Old 02-21-2012, 01:23 AM   #15
OK, it worked like a charm. I tripped the breakers on the right side and also a couple on the left side that came through the right side just to be safe, capped and labeled the two wires. After replacing the panel cover, I tested the wires from the wall, then cut them back a bit, then capped those off too. Finally, repaired the wall, so now the paint in drying!!
I appreciate everyones suggestions and help! The wall looks perfect now.
tacking wire in wall Clutchcargo Electrical 4 10-08-2011 09:32 AM
Stucco transition from wire & paper to block wall jmk909er Building & Construction 0 07-17-2011 09:39 PM
Question about neutral wire through wall switch guitarmonster Electrical 33 08-08-2010 09:51 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
