Old 01-18-2013, 05:15 PM   #1
How close together can holes be in joists?
I am running three new circuits for my new shop. There are existing holes but they are pretty full, so I will need new ones. How far away do the new ones have to be from the existing ones. I haven't actually measured them, but they are about 1.5".
The joists are plywood on the top and bottom, with a flake board web. (well maybe not flakeboard, but you know what I mean...)
Toller is offline   Reply With Quote
Old 01-18-2013, 05:28 PM   #2
No we do not know what you mean, got a picture?
Are these engineered joist?
http://maner.com/Engineered%20Lumber...le%20Chart.pdf
Old 01-18-2013, 05:41 PM   #3
1.5 inches is fine. Some engineered joist companies print the drilling info right on the product some you have to get a spec sheet. A couple of 3/4" - 1" holes should be no problem.
BTW , it's called oriented strand board (osb)
danpik is offline   Reply With Quote
Old 01-18-2013, 06:11 PM   #4
Okay, I did a search for my TJI 230 and found a similar chart. 1.5" holes are allowed anywhere as long as they are 6" from the supports. Midpoint between the joists two 1.5" holes can be right next to each other. So that pretty much answers my question; thanks.
A related question... it obviously is okay to nail into the flanges to put in pipe hangers and the like. I am going to put up two 50 pound air filters. Since they are supported in 4 places, it wouldn't be more than 20 pounds from any support. Is a screw eye into the flange okay? Is screwing into the bottom or side better? The alternative would be to put a chain though a hole in the web, and that doesn't seem right.
holes in floor joists Mogily Building & Construction 4 03-06-2012 08:47 AM
Hydronic radiant heat and joists Red Squirrel Building & Construction 3 01-14-2011 04:01 PM
romex holes close to edge artmark Electrical 6 10-29-2010 10:15 AM
cutting 4" holes in 10" floor joist red_cabby Building & Construction 19 06-22-2010 05:25 PM
Gun Safe vs. Floor Joists allen1466 Building & Construction 9 03-03-2006 09:16 AM
