How Close Can A Potlight Be To Natural Gas Pipe? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-21-2009, 12:00 PM   #1
How close can a potlight be to natural gas pipe?
I wasn't able to find anything regarding this subject anywhere and Atco is closed until Monday(Doubt a customer service rep would have a clue)
In my basement hallway ceiling is an ugly iron gas pipe(1 1/2" I think) hanging about 1/4" below the drywall. I have a 3" 50W potlight that I was planning on putting up
Would it be fine to place a potlight 1 1/2"'s away from the gas pipe without any problems or dangers?
The hallway celing has the rectange duct trunk running down the middle with drywall butted against it on both sides. Left side has 9 1/2" of drywall the the right has 13 1/2". As it is a 6' person's head will have about 1" of clearance under the duct if they walk down the middle of the hall(I have no idea what the HVAC guy was thinking)
Thanks guys!
DrmChld is offline   Reply With Quote
Old 09-21-2009, 01:37 PM   #2
Rewards Points: 236
It's Monday. What did they say?
If it worked before you worked on it. You did something wrong.
J. V. is online now   Reply With Quote
Old 09-21-2009, 02:01 PM   #3
Vann
There is no problem at all with this.
vann is offline   Reply With Quote
Old 09-21-2009, 04:21 PM   #4
Gas company said to contact a mechanical engineer who does gas lines. Pot light maker says to contact gas company
Old 09-21-2009, 04:55 PM   #5
This link
http://www.tcforensic.com.au/docs/article10.html
has the ignition temp. of NG.
Your "digital probe" will tell the temp. of the pipe or the can light housing.
no burn ever at 42C(108F)
burned in 30 sec at 54C(129F)
5 sec at 60C(140F)
1 sec at 71C(160F)
"The glass bulb of a general service lamp can reach temperatures between 200 and 260 degrees Celsius (400 to 550 degrees Fahrenheit)."
Seems like you can have your gas pipe touching the bulb.
Possible to join PVC drain pipe to old iron pipe? darsunt Plumbing 7 03-01-2014 01:53 PM
AC Coil drain pipe questions fritzycat1 HVAC 14 11-12-2010 03:51 PM
natural gas pipe line dave444 Plumbing 7 08-01-2009 09:54 AM
stuck iron pipe on oil tank vent wrybosome Plumbing 3 01-13-2009 09:43 PM
PVC pipe broken on Gas Furnace/AC unit Keyo77 HVAC 8 10-16-2007 03:08 AM
