-   -   How to choose light switch styles (for 2 and 3 gangs) (http://www.diychatroom.com/f18/how-choose-light-switch-styles-2-3-gangs-21979/)
jelly 06-08-2008 01:16 PM
101 Attachment(s)
Do you consider the light switch plate cover when deciding the style switch you are going to use? This may seem like dumb question.
I have a 3-gang box with two regular switches. the third is a dimmer so would it be obvious to choose the dimmer with the small slider vs. the dimmer with the large slider? this way i can simply use a standard 3 switch plate cover which i can easily find.
I prefer the dimmers with the larger sliders but finding a plate cover with two small rectangles and one large is not easy... or is it?
Also, what about putting a rotary dimmer next to a regular switch? I suppose I could buy a solid cover and custom make my own openings.
Basically, is there a rule of thumb when purchasing a switch style when you have multiple switches in a box?
http://www.lutron.com/products/dimme...ylark-copy.jpghttp://images.acehardwareoutlet.com/...=120&width=120http://www.lutron.com/products/dimme...iadni-copy.gifhttp://www.lutron.com/qoto/?s=17000&t=17200http://www.acehardwareoutlet.com/%28...ge=3200953.jpg
BigJimmy 06-08-2008 01:22 PM
I'm surprised. I can find mutli-gang covers at my local Borg with a variety of small and large cutouts. You can also find a ton of places on-line that offer a lot of combinations.
As far as the rotary dimmers are concerned, you typically just use the small rectangular opening. The knob conceals the opening anyway.
Super33 06-08-2008 01:52 PM
Different plates are easy to find, I suggest focusing your attention to the actual switch you want then buying a plate to match.
