How To Check Electrical Outlets For The Right Connection? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-16-2012, 04:05 PM   #1
Question
How To Check Electrical Outlets for the right connection?
I was wondering how I can do that. I know there is a small bunch of testers available, but which one? I am moving into a new place, and want to do this myself. Any ideas are welcome.
DIY Curious is offline   Reply With Quote
Old 04-16-2012, 04:14 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Are you renting or buying?
Speedy Petey is online now   Reply With Quote
Old 04-16-2012, 05:14 PM   #3
Rewards Points: 6,652
The right tester is what is between your nose. The second best one out there costs more than you realize. It generally runs about $290. Ideal Suretest
Old 04-16-2012, 05:39 PM   #4
DIY Enthusiast
sublime2's Avatar
You can start with something like this;
sublime2 is offline   Reply With Quote
The Following User Says Thank You to sublime2 For This Useful Post:
electures (04-16-2012)
Old 04-16-2012, 08:31 PM   #5
Too Short? Cut it Again!
Attachment 49152
Ditto. An outlet tester is the place to start. Get one that tests the usual and fault interruption. Trigger and test the fault interruptors with the onboard test switches too.
You will want a simple voltage tester for switches, light and ceiling fan connections, etc. too.
If you get into this, you will find many uses for a multi-tester and learning to use one can save you some money in doing preliminary diagnoses prior to bringing in an electrician. THERE IS NO SUBSTITUTE FOR A QUALIFIED ELECTRICIAN THOUGH! When in doubt, or most times even when you are absolutely sure, call one. They are much cheaper than house fires.
Old 04-16-2012, 09:10 PM   #6
Missouri Bound's Avatar
Get the plug in tester first. If your experience grows and you want to do more you can always get a multimeter.
Do you want it your way or the right way?
Old 04-16-2012, 09:30 PM   #7
I=E/R
a7ecorsair's Avatar
I'm having a hard time understanding this because I only have one nose so how can something be "between" it?
a7ecorsair is offline   Reply With Quote
The Following User Says Thank You to a7ecorsair For This Useful Post:
Old 04-16-2012, 09:31 PM   #8
Old 04-16-2012, 09:36 PM   #9
Your eyes, goof. If you can not tell visually if something is amiss, then next step is the tester, or vice versa. I never trust the testers, because they can not tell you if there is a "bootlegged" ground, without actually taking the cover plate off the outlets.
Tags
connection , diy , electrical outlet , tester , testing
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 01:29 PM
After storm, Electrical Outlets not working DougP Electrical 4 09-03-2011 05:56 PM
electrical outlets exterior jeff caldwell Electrical 2 05-30-2011 06:30 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
tiling kitchen...how to deal with electrical outlets in floor? tarheelblue Electrical 4 01-29-2008 11:40 PM
