How To Check 240v Baseboard Heater...without Connecting Supply Wires And Thermostat? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-21-2012, 03:34 PM   #1
Rewards Points: 71
How to check 240v baseboard heater...without connecting supply wires and thermostat?
Without connecting thermostat or supply wires..how can I just check the heater if its working... ...is there any way we can check using ohmmeter ...(resistance)...
if yes...please explain how...
if its not possible to check without power supply to it...please explain how to connect power to it..without involving thermostat.
vikasintl is offline   Reply With Quote
Old 09-21-2012, 03:37 PM   #2
joed's Avatar
Rewards Points: 11,614
Put the ohm meter across the two wires from the heater and see if there is continuity. You might even be able to find out what the resistance should be by checking the manufactures sight. If not then watts divided by volts should give you a rough idea of what it should be.
If the last test checks out then you should test from each line to ground. It should be open with no connection.
How to connect double thermostat on right side...withtout supply wires vikasintl Electrical 0 09-21-2012 02:55 PM
80 Gallon Water Heater Thermostat myowneq Electrical 26 02-13-2012 11:50 AM
Thermostat for electric baseboard wiring help needed vae_victis HVAC 10 01-05-2012 11:53 AM
Baseboard Heater Thermostat Ground Wire ? sciron Electrical 6 02-19-2011 06:28 PM
Issue with thermostat wiring for baseboard heater jschell Electrical 3 01-30-2011 08:30 AM
