How To Change Wiring In Walls W/o Damage? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-09-2012, 09:57 PM   #1
Rewards Points: 248
how to change wiring in walls w/o damage?
I want to rearrange some wires in a wall and on the ceiling. Dividing up a big room into two smaller ones. Problem is that the wires are under drywall. No clear way to get at them. Tearing the walls and ceiling apart and putting it back together is a big drywall job. Is there any way to rearrange wires inside a wall and ceiling without tearing things apart?
jackwashere is offline   Reply With Quote
Old 10-09-2012, 11:23 PM   #2
Rewards Points: 2,212
In some cases wires can be disconnected and labeled as such, then just run new wires with fish tape.
mae-ling is offline   Reply With Quote
Old 10-10-2012, 06:31 AM   #3
Rewards Points: 2,516
Do you mean physically move the cables? What if they are stapled to the studs?
hammerlane is offline   Reply With Quote
Old 10-10-2012, 07:02 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 2,116
That is your big problem....they 'should' be stapled. If so, it can be a b!tch to get the wires out. I moved one 2 weeks ago....short distance.....3'.....I was lucky in that the staple was not too tight and I could pull the wire out....not easy.
Drywall is not that hard. In my personal opinion, it's easier to just cut some big sections out and do what you need to do with wire than try to pull and fish new wire. That is of course after you have verified that the wire is stapled and you have fireblocks in the way.
A Variety of Damage to the Walls... Newbie Needs Advice Sile Drywall & Plaster 7 09-11-2011 03:47 PM
Should new wiring be protected from damage prior to drywalling? Mi Feller Electrical 6 07-25-2010 01:10 AM
Smoke Damage:Must Walls be torn out or will Clean / Repaint Work? Solo1 Remodeling 1 10-16-2009 01:20 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 08:17 AM
Need some advice on buying home termite & water damage. Mr Heshup General DIY Discussions 1 03-29-2009 03:06 PM
