How Can I Wire My New Replacement Range Hood/fan? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-12-2013, 03:49 PM   #1
How can I wire my new replacement range hood/fan?
I suppose I'll end up calling an electrician but I'm fairly handy and willing to learn and try.
Here's the story. California home built in 1965. The old kitchen range hood was direct wired. It has been removed. There is now a metal conduit with one red wire and one white wire coming out of the ceiling.
The new range hood/fan has a 3 prong plug ready to be plugged into an outlet. Manual says its 120V, 60Hz.
Can I simply install a metal electric box in the ceiling area and hook up an outlet? What should I watch out for?
Thanks in advance.
Jack
alphajack7 is offline   Reply With Quote
Old 01-12-2013, 04:01 PM   #2
Rewards Points: 13,774
Why not just install an old work box in the ceiling and plug it in?
http://www.bing.com/images/search?q=...497CAF&first=1
Old 01-12-2013, 04:28 PM   #3
Rewards Points: 506
Send a message via AIM to theatretch85
The OP stated he has a metal conduit there currently, a metal box would be the best way to connect an outlet to the existing metal conduit. An old work box would be great if he had said there was romex in the ceiling.
theatretch85 is offline   Reply With Quote
Old 01-12-2013, 04:50 PM   #4
Oso954's Avatar
Rewards Points: 1,132
You need to worry about your ground. What type of "metal conduit" is that ?
If it is flexible, is it BX, AC, MC ?
You are probably better off calling in an electrician on this one.
Oso954 is online now   Reply With Quote
Old 01-12-2013, 05:07 PM   #5
I don't see any ground wire. Just flexible metal tube, about 3/4". original circa 1965. Not sure about BX,AC,MC.
Inside the conduit are just 2 wires, 1 red and 1 white. It was those 2 wires that wired up the 40 year old old range hood/fan/light.
Thanks for your help.
Jack
Old 01-12-2013, 05:18 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
What kind of hood fan has a cord and plug? This is not a micro/hood is it?
Old 01-12-2013, 05:35 PM   #7
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Per code, a cord connected range hood requires its own circuit.
The Following 4 Users Say Thank You to k_buz For This Useful Post:
Code05 (01-13-2013), J. V. (01-13-2013), Jim Port (01-12-2013), Speedy Petey (01-12-2013)
Old 01-12-2013, 05:51 PM   #8
Not a micro.
http://rangehoodreview.wordpress.com...-hood-gvai-30/
Old 01-12-2013, 05:51 PM   #9
Thanks for the info. I'll call an electrician.
Old 01-13-2013, 11:38 AM   #10
Rewards Points: 174
Pete. This is the second time here recently that someone had a range hood with a manufacturers cord and plug on it.
I have never seen this myself. All the hoods I have ever used had a junction box and KO for a cable.
I don't get it? A range hoods wiring should be hidden IMO. Not plugged into a receptacle?
Any idea why some manufacturers are providing a cord and plug.
And can I remove the cord and plug and do it like I always have. Through the wall with NM and a NM connector?
Old 01-13-2013, 12:00 PM   #11
Licensed electrician
Rewards Points: 1,634
Maybe this is an effort to make it easier for an HO to install instead of needing to know how to wire something?
Speedy Petey (01-13-2013)
Old 01-13-2013, 12:09 PM   #12
JOATMON
ddawg16's Avatar
Rewards Points: 1,836
What you commonly find here in CA, they put a cabinet above the vent hood and put the outlet inside the cabinet....usually behind the vent pipe that goes up through the cabinet....
ddawg16 is online now   Reply With Quote
Honeywell vision pro, fan always on? and True Steam problem c5sb HVAC 6 06-19-2012 09:08 PM
ceiling fan wicked97 Electrical 4 08-21-2011 08:12 AM
4 wire range hook up on 220 outlet greenhorn1 Electrical 7 08-12-2011 07:50 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 01:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
