-   -   How can I wire my new replacement range hood/fan? (http://www.diychatroom.com/f18/how-can-i-wire-my-new-replacement-range-hood-fan-168931/)
alphajack7 01-12-2013 03:49 PM
I suppose I'll end up calling an electrician but I'm fairly handy and willing to learn and try.
Here's the story. California home built in 1965. The old kitchen range hood was direct wired. It has been removed. There is now a metal conduit with one red wire and one white wire coming out of the ceiling.
The new range hood/fan has a 3 prong plug ready to be plugged into an outlet. Manual says its 120V, 60Hz.
Can I simply install a metal electric box in the ceiling area and hook up an outlet? What should I watch out for?
Thanks in advance.
Jack
joecaption 01-12-2013 04:01 PM
Why not just install an old work box in the ceiling and plug it in?
http://www.bing.com/images/search?q=...497CAF&first=1
theatretch85 01-12-2013 04:28 PM
The OP stated he has a metal conduit there currently, a metal box would be the best way to connect an outlet to the existing metal conduit. An old work box would be great if he had said there was romex in the ceiling.
Oso954 01-12-2013 04:50 PM
You need to worry about your ground. What type of "metal conduit" is that ?
If it is flexible, is it BX, AC, MC ?
You are probably better off calling in an electrician on this one.
alphajack7 01-12-2013 05:07 PM
I don't see any ground wire. Just flexible metal tube, about 3/4". original circa 1965. Not sure about BX,AC,MC.
Inside the conduit are just 2 wires, 1 red and 1 white. It was those 2 wires that wired up the 40 year old old range hood/fan/light.
Thanks for your help.
Jack
Speedy Petey 01-12-2013 05:18 PM
What kind of hood fan has a cord and plug? This is not a micro/hood is it?
k_buz 01-12-2013 05:35 PM
Per code, a cord connected range hood requires its own circuit.
alphajack7 01-12-2013 05:51 PM
Not a micro.
http://rangehoodreview.wordpress.com...-hood-gvai-30/
Thanks for the info. I'll call an electrician.
J. V. 01-13-2013 11:38 AM
Pete. This is the second time here recently that someone had a range hood with a manufacturers cord and plug on it.
I have never seen this myself. All the hoods I have ever used had a junction box and KO for a cable.
I don't get it? A range hoods wiring should be hidden IMO. Not plugged into a receptacle?
Any idea why some manufacturers are providing a cord and plug.
And can I remove the cord and plug and do it like I always have. Through the wall with NM and a NM connector?
Jim Port 01-13-2013 12:00 PM
Maybe this is an effort to make it easier for an HO to install instead of needing to know how to wire something?
ddawg16 01-13-2013 12:09 PM
What you commonly find here in CA, they put a cabinet above the vent hood and put the outlet inside the cabinet....usually behind the vent pipe that goes up through the cabinet....
