How Can I See The Watt Draw From A Generator? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-11-2009, 11:03 PM   #1
How can I see the watt draw from a generator?
I have one of these (pic below) which shows how many watts my electrical devices use in Watts. Is there a similar device that would allow me to see how many watts my generator is using through the 240 plug?
It would be nice to just step out and read how hard my generator's working.
(For instance: If I was running several appliances... I could step out and see if I had enough free wattage to run my coffee maker)
deeze is offline   Reply With Quote
Old 07-12-2009, 08:43 AM   #2
Assuming a constant ~240v just use a clamp-on ammeter and multiply the amps by 240. V x I is close enough to the wattage for this application.
How many watts is your gen. rated for?
Old 07-12-2009, 08:45 AM   #3
Rewards Points: 20
I was looking into one of these for a standby generator
http://nooutage.com/RMK.HTM
I found another product that had a row of LED's to indicate amps but I can't find the link. It worked the same way.
Edit. The LED meter is also by the same company. Just follow the link
dcopps is offline   Reply With Quote
Old 07-12-2009, 09:30 AM   #4
It's a portable 8000/13500 Briggs and Stratton
Here's a picture from a random web site:
http://www.electricgeneratorsdirect....0210/p887.html
Old 07-12-2009, 09:35 AM   #5
WOW... this is fantastic dcopps! Could I just attach this to my generator breaker switch and install it in the wall right beside my electrical panel (in garage)? That would be 100% perfect!!!
Old 07-12-2009, 10:49 AM   #6
So your wattmeter needs to handle 33A to 56A, assuming 240v, and double this current at 120v.
Old 07-12-2009, 11:35 AM   #7
Will this work: http://nooutage.com/RMK.HTM
Old 07-12-2009, 03:35 PM   #8
Apparently, but the disclaimer about 10 kW, min., is puzzling.
This link is very short on specifics. Be careful. If you e-mail them with questions but they call you back with answers, be especially careful.
Old 07-12-2009, 03:58 PM   #9
Brilliant thought. I can hear them now "put nothing in writing".
Are there similar devices out there? I've been Googleing around trying to find one with a better picture and more specs.
Old 07-12-2009, 04:03 PM   #10
Same principle:
http://www.theenergydetective.com/index.html
jerryh3 is offline   Reply With Quote
Old 07-12-2009, 04:12 PM   #11
Okay, so I got everything set up today and the generator easily turned over my 4 ton variable speed ac system (it does have a KickStart or something installed on heat pump... not sure exactly what they called it... dampens the initial electric kick when it starts.). I could also run my refrigerator and 60" plasma at the same time... AWESOME!
I have everything in my entertainment center running to two power strips... one that has only my TV, Dish Receiver and DVI Switcher and then a second power strip that says "turn off while on generator". that kills the power to all the other unnecessary stuff like computer, security camera hub and other stuff.
ANYWAY, I hooked the amp meter to the black wire within my emergency disconnect (only place I could access it) BUT is just reading that one wire enough? Isn't the white wire hot too? I'm a little confused and uneducated in this area. However based on the math equation you gave me Yoyizit, the ac system running alone was drawing 16amps or 3,840watts. Small price to pay for central air in FL!
Old 07-12-2009, 04:14 PM   #12
Here's what inside of them
http://electronicdesign.com/Articles...6411/6411.html
Yes, 16A is plausible, yes, just the hot wire. The neutral wire has the same current in it unless you have problems. The current goes out on one wire and returns on the other.
10 cents/kwh in FL but 4600 Cooling Degree Days/yr in Miami. What do you pay for year round cooling in FL? If this 16A, 240v thing runs 8 hrs/day, it's ~$3/day.
But your engine/generator is maybe 20% efficient so depending on the price of gasoline you will be paying quite a bit more per kwh. 1 gal of gasoline converts to 38 kwh at 100% efficiency.
With your setup, you could post back with how long one pint of gasoline runs your HVAC system. . .
Not that I'm asking you to do this. . .
Old 07-12-2009, 05:42 PM   #13
Rewards Points: 20
Seems the RMK watt meter offered by nooutage is made by gen/tran. The following link is the manufacture website.
http://www.gen-tran.com/eshop/10Brow...ategory=MTSOPT
The price on nooutage website has not been updated since 7/1/08 so it might be safer to get it direct from gen/tran
Old 07-12-2009, 05:52 PM   #14
Are they both reliable sources?
The NoOuttage.com price (after shipping) is: $65.28
The Gen-Tran.com price (after shipping is: $81.75
$16.47 difference
Do you suppose I will receive the exact same product from either company?
Old 07-12-2009, 06:14 PM   #15
Rewards Points: 20
That's a good question.
I would call nooutage and make sure the price is current.
I going to order mine from Gen/Tran (the manufact) just to be safe
8000/13500 Watt Generator House Hookup Questions deeze Electrical 17 07-11-2009 11:57 AM
Generator with 2 transfer switches? Isaac-1 Electrical 4 03-16-2009 07:45 PM
Well Pump to Generator Question Sprice Electrical 1 02-11-2009 11:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
Feeding multiple subpanels with a single generator monsoon Electrical 8 10-02-2007 04:25 PM
