How Can I Install A Power Switch On My Compressor? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-27-2010, 12:00 AM   #1
Rewards Points: 91
How can I install a power switch on my compressor?
I just redid my compressor. Tore it apart and degreased it and repainted. Put in new copper tubes and fittings and also new wiring. Looks mighty fine. However, it does not have a power switch. Its just a "plug-in". The pressure switch does not have a switch on it. I am considering an in-line switch for lack of a better idea, short of replacing the pressure switch. I have not priced pressure switches yet. I already have $40 wrapped up in the "clean-up" and prefer not to spend more than a couple dollars more. What do you recommend for a switch? By the way, its 220V.
How can I install a power switch on my compressor?-dcp_2983.jpg   How can I install a power switch on my compressor?-dcp_2984.jpg
sofasurfer is offline   Reply With Quote
Old 09-27-2010, 04:04 AM   #2
Electrical Contractor
kbsparky's Avatar
You could mount a switch box, and install a 20 Amp 2-pole wall switch in it. That should do the trick.
A 4x4 "1900" box should give you adequate room.
-KB
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
Trying to install Leviton In-Wall LCD timer switch Proulx06 Electrical 36 11-05-2009 11:15 PM
New outlet using power from a nearby switch. surecook Electrical 23 10-16-2009 07:27 PM
Need Help Troubleshooting 3-way + Single Pole Switch Install OmegaRed1723 Electrical 6 10-09-2009 11:25 PM
