How Can I Install A New Light Fixture From A Current Light Fixture? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-11-2012, 07:18 PM   #1
Smile
How can I install a new light fixture from a current light fixture?
Hello. I am looking to install another low wattage ceiling light in the hall of my home, and would like to tap into the current light fixture in the hall which is controlled by a single switch. I am very handy.
Thanks!
MikesHouse is offline   Reply With Quote
Old 11-11-2012, 07:23 PM   #2
Master Electrician
Rewards Points: 3,920
Access above the existing fixture? Find out the wire size used at the existing fixture, install new cable sized to the original from existing location to the desired new location, connect wire at old location, install j-box for new fixture, install wire in new j-box, connect to new fixture and mount the fixture.
brric is online now   Reply With Quote
Old 11-11-2012, 07:36 PM   #3
Yes the existing fixture is in the ceiling and the attic is right above it.
Thanks for the tips! Sounds easy enough.
Old 11-11-2012, 07:39 PM   #4
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Where is the power,in the fixture or the switch?
The wire at the switch,is it 2 blacks or a black and white?
sublime2 is offline   Reply With Quote
Old 11-11-2012, 07:46 PM   #5
There are 2 black wires going to the switch.
Old 11-11-2012, 07:47 PM   #6
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
What does it matter?
The Following User Says Thank You to k_buz For This Useful Post:
brric (11-11-2012)
Old 11-11-2012, 07:57 PM   #7
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
You mean,
why does it matter?
It doesn't.
Help! I need to install a new light fixture! dispietate Electrical 6 10-17-2011 04:18 AM
How many wires can be tapped into a light fixture? JayBird Electrical 6 07-11-2011 02:44 PM
Problem installing exterior light fixture Lynch Electrical 14 08-25-2010 06:25 AM
Hall light worked before installing a new light fixture in bathroom jcfan7 Electrical 40 02-23-2008 09:46 AM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 09:44 PM
