How Can I Find Out Which Outlet A Wall Switch Operates? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-12-2013, 06:39 PM   #1
How can I find out which outlet a wall switch operates?
How can I find out which outlet a wall switch operates? I have a room with a wall switch that is suppose to operate one of the outlets. However, I have not be able to figure out which outlet. The switch has a single romex line with white, black, red and ground wires. The black is connected to the bottom terminal, the red to the top, and the ground is connected to the green terminal. The white wire is not connected to anything.
tom36 is offline   Reply With Quote
Old 03-12-2013, 06:47 PM   #2
Electrician
Most likely only half of the receptacle is switched. With the switch in the off position go to every outlet and see which one doesn't have power. Check both the top and bottom of each outlet.
Licensed Electrician MA, CT, RI, NH, VT
EBFD6 is offline   Reply With Quote
Old 03-12-2013, 06:51 PM   #3
Rewards Points: 50
With the switch in the off position, plug a lamp or radio into the recepticles in that room. Be sure to try both halves of each recepticle as it is possible that only one side is switched. When you find where the lamp or radio doesn't work, leave it plugged in and try the switch.
daveb1 is offline   Reply With Quote
Old 03-12-2013, 07:14 PM   #4
joed's Avatar
Rewards Points: 13,752
If someone changed a receptacle that was supposed to be half switched and did not break the tab then none of them will be switched. If you can not find a switch one then turn off the power and remove the receptacles. Look for the tab between the black and red wire to be cut.
The Following User Says Thank You to joed For This Useful Post:
mpoulton (03-12-2013)
Old 03-12-2013, 08:00 PM   #5
DIY staff
Rewards Points: 7,174
The simple way to figure out if a tab was not removed?
Put a tester on the bottom screw of the switch---in the 'off' position-
then test the top screw---
if both are hot when the switch is off----you have the switch leg getting power because an outlet did not have the tab broken off.
Old 03-12-2013, 09:00 PM   #6
Licensed electrician
Rewards Points: 1,892
Without the white connected the receptacle will not work or someone miswired it.
Well pressure switch and outlet BrandonD Electrical 8 10-09-2012 08:47 AM
Light fan burn out, wall switch backwards later LOYD DUNCAN Electrical 1 09-18-2012 06:49 AM
Replacing a wall outlet dimmer switch with a rocker switch Lonepine Electrical 1 01-05-2010 10:18 AM
Electrical outlet controlled by a wall switch? rinlo Electrical 14 12-28-2008 10:30 PM
Adding an outlet to a wall switch Keyo77 Electrical 6 01-01-2008 11:22 PM
