How Can I Disable A Light Switch So Its Always On? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-14-2009, 05:56 AM   #2
300zx's Avatar
Post
Pull the switch out is it a single polr switch ? If so TURN POWER OFF AND TAKE THE TWO WIRES OFF SWICH SHOULD BE 2 BLACKS BUT NOT ALWAYS THE TWO WIRES ON THE SCREW TAKE OFF AND WIRENUT THEM TOGETHER AND THEN PUT SWITCH BACK IN FOR A DUMMY OR GET A BLANK PLATE TO COVER AND TURN BREAKER BACK ON ONLY PROB IF YOU HAVE A POWER OUTAGE FOR A SEC THE LIGHTS ARE PROGRAMED TO STAY ON SO YOU WOULD HAVE TO SHUT THE BREAKER OFF FOR A COUPLE OF SECONDS AND BACK ON TO RESET LIGHT.NEED MORE HELP THERE ARE ALOT OF GREAT PEOPLE HERE THAT CAN GET YOU IN TH RIGHT DIRECTION.
300zx is offline   Reply With Quote
Old 10-14-2009, 07:04 AM   #3
I would install a switch guard first it's the easiest, fastest, safest way to keep the switch on all the time.
You should be able to purchase it anywhere or a blank plate that was already recommended.
SULTINI is offline   Reply With Quote
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 09:02 AM
Tracing light switch to an outlet allanet Electrical 13 04-03-2009 08:44 AM
A simple 2 light --1 switch question? redondo11@msn.com Electrical 7 11-05-2008 08:35 AM
no power going to the light switch baseballfan Electrical 18 09-08-2008 05:35 PM
Problem changing light switch grgryl Electrical 14 08-10-2008 01:26 PM
