How Can I Determine The Size Of A Starter Capacitor? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-23-2012, 06:27 AM   #1
just a tool guy
mickey cassiba's Avatar
How can I determine the size of a starter capacitor?
My Lathe has a bad starter cap. The cap is unmarked. The machine has been out of production for a few years now, and replacement parts are unavailable. Can any one here give me a reliable way to determine the size(uf, and voltage) of the capacitor using a multimeter? It's on a 1/2 horse Delta lathe, and is not a variable speed motor. Delta has not been forthcoming with the specs.
Thanks in advance...
Mickey
One of these hammers will fix it.
mickey cassiba is offline   Reply With Quote
Old 02-23-2012, 10:07 AM   #2
Rewards Points: 3,130
You're not going to find out what you need to know using a multimeter. They measure voltage, current, and resistance. Capacitance is a whole different thing.
Delta probably did not manufacture the motor. Does it have a nameplate (most do). With the information on that, the manufacturer or perhaps a motor rebuild shop could probably fix you up.
Old 02-23-2012, 10:41 AM   #3
Missouri Bound's Avatar
Here's some generic information that may help you....good luck Single phase capacitor sizing
Do you want it your way or the right way?
The Following 2 Users Say Thank You to Missouri Bound For This Useful Post:
mickey cassiba (02-23-2012), zappa (02-23-2012)
Old 02-23-2012, 11:58 AM   #4
just a tool guy
You're right, Delta didn't make the motor....it was sourced from China. Delta has a really bad habit of removing identifying marks and data...I guess it's to keep selling their over priced repair parts( I should know....I worked for them for a long time), but in my case it's discontinued.I was trying to avoid the motor shops, I'm pretty cheap, but if the tools I have won't get the answers I need, I might have to go for it. I do have a tester that will tell me(go/no go) the status of a cap, but it doesn't read out any data...just a red or green light.
Mickey
Old 02-23-2012, 01:05 PM   #5
just a tool guy
Wow...good stuff there...it'll likely come in handy someday( I do like to tinker and have built a few simple machines.
Mickey
Old 02-23-2012, 01:08 PM   #6
Glad to help.............
Old 02-23-2012, 02:27 PM   #7
Another way is to measure the volume of your capacitor in cubic inches (for complex shapes use mensuration formulas) and compare this volume to similar capacitor dimensions for 1/2 hp motors from catalogs.
You are converting volume to capacitance and working voltage. Probably a 2x increase in volume equals a ~2x increase in capacitance or a ~2x increase in working voltage.
First figure out your minimum working voltage. AFAIK this is way less critical than the capacitance value.
The correct value can probably be approximated pretty well by using the link and this method.
Old 02-24-2012, 07:50 PM   #8
just a tool guy
Okay...I found the specs on the capacitor...It's a 30 mfd, 300volt cap, the configuration is 'CBB60SH' I cannot find this combination. Now comes the next question...what is the most important match, the capacitance value, or the voltage. Physical size is irrelevant, I can make a new cover. The closest match I can find is a 30 mfd, 370VAC. Will this work without fryin' my motor?
Mickey
Old 02-24-2012, 07:57 PM   #9
Rewards Points: 266
Yup, the capacitance value is the important thing. Voltage rating can be higher than the old one. In the case of the replacement being 370 V, that is perfectly OK. All it means is the new capacitor is capable of being exposed to higher voltage. The capacitor will probably not see voltages above 120 volts anyway.
junkcollector is offline   Reply With Quote
The Following User Says Thank You to junkcollector For This Useful Post:
mickey cassiba (02-24-2012)
Old 02-24-2012, 08:00 PM   #10
just a tool guy
Cool....the part I found has a capacitance of 30-36 mfd...will that variable mess with me?
Mickey
Old 02-24-2012, 08:03 PM   #11
Rewards Points: 266
Nope, that should work fine.
Old 02-25-2012, 10:35 AM   #12
The old capacitor may show a tolerance marked on the case, like 30 uF, +10%, - 50%.
You are less likely to have problems if your new cap has a value, including the tolerance, within this range.
Old 02-25-2012, 11:16 AM   #13
just a tool guy
The old cap has no markings whatsoever...a common ploy by Delta to keep end users strung out on their high priced replacement parts.My new cap should be here in a few days....we shal see what happens.
Mickey
Proper trunk/duct size? gjones HVAC 7 12-06-2011 07:18 PM
Air Compressor Capacitor Question tlwright6 Electrical 3 10-19-2011 11:04 AM
capacitor problem cpowell243 Electrical 6 10-11-2011 09:58 PM
Capacitor size differences Doc Holliday HVAC 19 08-01-2011 06:38 PM
how determine size of service tikicarver Electrical 2 01-29-2008 08:10 PM
