#16 | |
how to calculate box fillQuote:
All grounds=1 switch=2 14+1+2=17 (providing the box doesn't have internal clamps) |
#17 |
You were right with 20cu in
All grounds count as 1 conductor which counts as 2 The switch counts as 2 conductors which counts as 4 If you are using 14 ga. 7x2=14 1x2=2 2x2=4 14+2+4=20 |
#18 |
Xtreme DIY'r
I always go oversize on boxes since I use 2x6 walls
After trying to insert what fits under code its a good idea to go slightly larger if you acn |
#19 | |
2 14/2 = 4 wires at 1 volume = 4 x 2.0 = 8 1 14/3 = 3 wires at 1 volume = 3 x 2.0 = 6 all grounds = 1 volume = 1 x 2.0 = 2 One switch = 2 volumes = 2 x 2.0 = 4 Total is 20 cubic inches. I am still new at this but I believe this is right. |
#20 |
Electrician
I came up with 20 cu in.
#21 |
Thanks everyone. I understand it now. Guess I had it right the first time and when I went back to double check I only counted the switch as one volume. Thanks again everyone for sharing your knowledge!
#22 |
Licensed Electrician
I think it's great that this thread will be found during searches and give accurate and good advice to many people in the future.
John |
#23 |
It surprises me that someone does not have a "calculator" for this. I made an excel spreadsheet which I am still testing but so far it has worked great. Just plug in numbers and you get a result. I did see some software for all types of calculations but it is a bit expensive.
#24 |
People that do it everyday barely think about it. For instance we know that a 2 gang switch box (32 CI) is ok with 2 14-3 and 2 14-2 along with 2 three way switches. That would be two 3 way circuits at the 2nd set of switches, or at the 1st set of switches with the line set continuing to another box. Or a single gang receptacle box (20.3) is ok with 3 12-2 and a receptacle outlet. And those are the most common filled up situations. Most boxes would have less wires that that in a typical circuit layout. Those are the ones which approach the fill limit.
John |
| Display Modes | |
| Building a shed, need help with pouring slab / fill | ssybert | Building & Construction | 5 | 06-12-2008 07:19 AM |
| cinder bloc shed - fill or no fill ? | amakarevic | Building & Construction | 3 | 04-16-2008 10:07 PM |
| sheetrock mud...how big a gap will it fill? | analogmusicman | Building & Construction | 2 | 02-23-2008 08:53 PM |
