How To Bypass Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 06-12-2013, 02:26 PM   #1
Rewards Points: 248
How to bypass switch
Hello, I need to create a bypass for this type of switch. This switch is on an old riding lawn mower. I could tape down the button but would rather bypass it. I would of posted this in the lawn care section but this is more electrical I would imagine.
http://www.amazon.com/104445X-Interl...d_sim_sbs_lg_2
thanks
jburchill is offline   Reply With Quote
Old 06-12-2013, 02:32 PM   #2
Oso954's Avatar
Rewards Points: 426
Without a good reason given, why would someone tell you how to bypass a safety interlock switch ?
Oso954 is online now   Reply With Quote
Old 06-12-2013, 02:34 PM   #3
custom user
Rewards Points: 150
It just connects the two conductors. Wire them together. I can't speak about the safety though, I don't know what the switch is for.
JasperST is offline   Reply With Quote
The Following User Says Thank You to JasperST For This Useful Post:
jburchill (06-14-2013)
Old 06-12-2013, 03:04 PM   #4
Rewards Points: 2,512
Thats most likely a seat switch.
hammerlane is offline   Reply With Quote
Old 06-12-2013, 04:03 PM   #5
Licensed electrician
Rewards Points: 1,020
How about Darwin was wrong?
Old 06-12-2013, 04:50 PM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 140
It is a kill switch for the seat so the mower shuts off when you get off, or fall out of the seat.
Old 06-12-2013, 05:06 PM   #7
Rewards Points: 248
its for the disengagement of the blade. The mower already starts up with the blades going. But when the lever is in the disengaged position the belt rubs against the mower deck. And the pulleys rub against the break pads. Causing it to start hard and wear out the belt. So I figured I'd just start the mower with the deck in the second highest position.
Yes I know its not safe, I've been trying to figure out how to get the disengagement to work. So if I need to get off the mower, I'll just shut it off, then get back on and start it up again.
Old 06-13-2013, 09:29 PM   #8
dmxtothemax's Avatar
Rewards Points: 5,096
You would be better off finding a mechanical solution for your problem,
rather than defeating the safety system of the mower.
You should consider some sort of tension pulley to keep the belt
away from the deck.
If you can't figure it out, post a picture of the underside of the deck
clearly showing the pulley system and the problem area.
Then we can find a solution for you !
dmxtothemax is offline   Reply With Quote
Old 06-13-2013, 09:40 PM   #9
sounds like things are not adjusted like they should be. i would think that it was not designed and manufactured with all that rubbing designed into it.
Old 06-13-2013, 10:33 PM   #10
JuzRick's Avatar
Thumbs up
away from the deck.
JuzRick is offline   Reply With Quote
Old 06-14-2013, 02:33 AM   #11
Rewards Points: 1,192
This post should be closed due to discussing bypassing safety devices.
bobelectric is offline   Reply With Quote
Old 06-14-2013, 07:05 AM   #12
Rewards Points: 1,214
Safety's often are the easiest things to bypass on a lot of things. They should never be bypassed.
The rubbing and wearing of belts should be investigated and repaired , leave the switch alone.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 06-14-2013, 12:35 PM   #13
Rewards Points: 58
It is simple to do and I have done it on my own riding mower.
I cannot tell you how, because if you get hurt, I might get hurt.
But it is very easy if you want to do it.
Old 06-14-2013, 01:15 PM   #14
joed's Avatar
Rewards Points: 11,572
It depends if the switch closes or opens when sit on it.
Old 06-14-2013, 01:19 PM   #15
Bill Kearney
Rewards Points: 1,174
So why not get THAT fixed instead?
wkearney99 is offline   Reply With Quote
confused on switch replacement fullpint Electrical 6 07-11-2011 09:39 AM
bypass pressure switch and draft limit switch vikingur HVAC 2 11-24-2010 05:55 PM
bypass motion sensing switch rickdog Electrical 5 04-01-2010 11:06 PM
4 way switch confusion Richo Electrical 10 04-09-2009 08:11 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
