How Best To Replace Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 10-06-2013, 09:14 PM   #1
Rewards Points: 370
how best to replace lighting
So I have this lighting I really like in my family room, as shown in the picture. It's a bunch of 4 foot 40 watt fluorescent tubes up there (F40T12 in case someone wants to ask). The row of lights is 270", or 22.5' long.
I'm having problems with some of them going out at various times and now they're not all turning out, so I'm facing having to muck with the ballasts.
I'd rather just go ahead and replace them all with LED strips in the hopes of cutting down the maintenance. The one problem I've seen is that I can't find one that is long enough. Any thoughts on how best to get around this? should I just make 2 chains, each half length?
Also, how do I match to make sure I match the brightness as I'd like to keep the overall amount of light put out? (this is my primary concern as I can't find a direct comparison from what I have in fluorescent tubes and convert that to an LED strip)
Thanks for the help!
MLMIB is offline   Reply With Quote
Old 10-06-2013, 09:45 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by MLMIB View Post
So I have this lighting I really like in my family room... a bunch of 4 foot 40 watt fluorescent tubes ... I'm having problems with some of them ... I'm facing having to muck with the ballasts.
It happens. Every fluorescent fixture needs it eventually.
How old are yours?
Do them all and at once and you should be good for a long while.
Plan to change to T8 lamps too.
Meh.
Old 10-06-2013, 11:20 PM   #3
dmxtothemax's Avatar
Rewards Points: 5,166
You can buy led strips at any length you want,
or use pre made and use as many as you need,
Either way works.
Since you already have wiring in place,
why not use 4ft lengths.
It's the easyest option, wiring wise.
dmxtothemax is offline   Reply With Quote
when to replace chimney marchaels Building & Construction 2 09-07-2011 07:36 PM
Solar Landscape Lighting - Any generate REAL light? 99altrade Landscaping & Lawn Care 4 08-02-2011 12:15 PM
Need to fix line voltage outdoor lighting noone Electrical 5 05-19-2011 11:49 PM
Replace or sister floor joists WillK Building & Construction 6 03-09-2011 08:55 PM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 09:47 PM
