How To Attach 3/4" Conduit To 1" Hole? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-24-2011, 03:41 PM   #1
How to attach 3/4" conduit to 1" hole?
I have what seems like a stupid question to me, but for the life of me, I can't figure it out. I'm attaching an external box to an (outdoor, so it needs to be water-tight) breaker panel. The external box has a 3/4" hole on it, but the panel only goes as small as 1".
I'm trying to figure out the proper way to adapt and attach the conduit. My current plan is to use the below as conduit between the two:
http://www.lowes.com/pd_153621-223-U...ductId=3127829
However, the problem I'm running into is I can't seem to find a way to enlarge the 3/4" nm conduit to fit a 1" hole in a manner that is water-tight. I've found 1" bushings, but I would have to glue them "through" the box, which doesn't strike me as a good idea (is that even allowable?)
As a side question, does it meet the NEC to simply terminate the conduit in the box that is 3/4" by screwing the female coupler through the hole? I can't come up with a reason not to do it, but figured I'd ask.
Thanks!
erickotz is offline   Reply With Quote
Old 08-24-2011, 04:19 PM   #2
Master Electrician
Rewards Points: 3,964
Mount a 1" terminal adapter with a locknut to the panel. Cement a 1" x 3/4" bushing in to the TA. Cement a short piece of 3/4" pvc into the bushing and into each end of your flex. Cement a TA to one end of your flex and cement the other end into the bushing. Screw the WP box onto the 3/4" TA.
brric is online now   Reply With Quote
Old 08-24-2011, 04:26 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Is this in the bottom of the panel? If so then it does not need to be watertight. You can just use reducing washers.
Old 08-24-2011, 04:30 PM   #4
Does that form a weather-proof seal? I would have expected to need an O-ring or similar in there.
Old 08-24-2011, 04:32 PM   #5
Master Electrician
An o ring where?
If that bothers you then use sealing washers.
Old 08-24-2011, 04:49 PM   #6
Electrician
Rewards Points: 802
Could you not drill your own hole in the panel for the 3/4 pipe fits.
darren is offline   Reply With Quote
Old 08-24-2011, 10:04 PM   #7
Rewards Points: 506
Make the 3/4" hole a 1" hole and use 1" pipe?
jlmran is offline   Reply With Quote
How to repair a hole in cast Iron pipe? bofusmosby Plumbing 26 11-13-2011 09:35 AM
3/4" vs 1" pvc rlaurent79 Plumbing 5 08-11-2010 08:42 AM
How to patch hole in duct work and drill new one? Studly HVAC 10 03-03-2009 09:26 AM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 10:28 AM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 07:17 AM
