How To Add/replace Outlets With Old 2-wire Wiring? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-30-2010, 09:47 PM   #1
How to add/replace outlets with old 2-wire wiring?
My terminology is probably way off, but I'd like to know how bad of an idea this is:
I gutted my entrance last week. The wiring is copper 2-wire with no ground wire in metal flexible conduit. It comes off a sub-panel (with breakers) and then goes to several other rooms and outlets. I don't have access to all of the wiring so I can't simply replace all of it --- maybe half?. Also, all of the outlets on this sub-panel are 2-prong with no ground wire (unless the conduit if the ground?).
I'm wondering whether this is ok or not: replace the wiring that I can get at with 14/2 and connect to the existing old wiring. And instead of running the bare ground back to the sub panel, run it instead to the main service panel that's nearby.
HautingLu is offline   Reply With Quote
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 01:29 PM
Wiring question: One switch controls 2 outlets mneumann Electrical 2 12-11-2009 01:49 PM
Correcting 40+ years of screwy wiring Badfish740 Electrical 3 12-28-2008 10:19 PM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 02:00 PM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 07:02 AM
