How To Add A Outlet Bos Useing 12/3 Wire? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-14-2009, 05:29 PM   #1
how to add a outlet bos useing 12/3 wire?
I am adding an outlet box. The box I am tapping into has 12/3 wire. What is the correct way to add on to this to put another box further over on the wall?
iambill is offline   Reply With Quote
Old 04-14-2009, 05:43 PM   #2
dSilanskas's Avatar
Call an electrician
dSilanskas is offline   Reply With Quote
Old 04-14-2009, 06:04 PM   #3
Is this how it is hooked up now?
Is half of the outlet controlled by a switch?
surrogate is offline   Reply With Quote
Old 04-14-2009, 06:07 PM   #4
yes that is the set up I have
Old 04-14-2009, 06:24 PM   #5
Assuming the red wire is the switched half, this will give you an unswitched outlet.
Old 04-14-2009, 06:30 PM   #6
I'll give it a try and let you know, Thanks for the help
Old 04-14-2009, 07:00 PM   #7
I had this outlet working this morning but now it keeps popping the breaker.
I have it wired up the same way as befor without adding in the new outlet and it still pops the breaker.
Am I useing an incorrect receptical?
Old 04-14-2009, 07:12 PM   #8
Did you replace the original receptacle with a new one? If so, did you break the tab connecting the top and bottom outlets?
Old 04-14-2009, 07:13 PM   #9
I think I figured it out.
The little metal tab between the screws holding the red and black wire had to be snapped out for it to work.
I guess it was arking.
I will finnish the job and let you know what happened
OK to use 12-3 to wire switched outlet? Jeremy Hillary Boob, PhD Electrical 7 04-04-2009 11:40 PM
how to wire an outlet? dmoneyz Electrical 10 04-02-2009 02:21 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
3 Wire 220 Volt Outlet theatretch85 Electrical 5 07-29-2008 02:35 PM
HELP I need to wire a switch to an outlet to hook up my garbage disposal r8drman69 Electrical 8 06-05-2007 11:18 PM
