How To Add An Outlet? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-19-2012, 12:39 AM   #16
blksith0's Avatar
Rewards Points: 12
Thanks Roch. However, I just discovered an outlet behind the wall in another rooml. Would that be okay to use? It would be really close by. Simply buy that romex wiring and cut some holes in the wall, and et cetera.
I'll let you know how it goes.
blksith0 is offline   Reply With Quote
Old 11-20-2012, 06:55 AM   #17
Rochsolid's Avatar
The closer the outlet the better. Let us
Know how it goes
Rochsolid is offline   Reply With Quote
Old 11-20-2012, 07:34 AM   #18
Licensed electrician
Rewards Points: 1,892
Whether you can use the receptacle on the other side of the wall would depend on the room and the purpose of the circuit. Some circuits cannot be shared.
Switched Outlet Issue mjm Electrical 13 06-14-2015 07:56 PM
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 04:14 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 09:13 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
