Old 11-17-2012, 04:38 PM   #1
blksith0's Avatar
How to Add an Outlet?
Hi, so I want to add an outlet to a wall, and I'm not sure how most people go about this, but I figured I would try and run an extension cord down the inside of the wall from the attic.
However I now realize that there's a lot of insulation in the way, so maybe not.
So how should I add an outlet to my wall?
blksith0 is offline   Reply With Quote
Old 11-17-2012, 04:43 PM   #2
You are off to a bad start. Call a capable electrician.
bobelectric is offline   Reply With Quote
The Following User Says Thank You to bobelectric For This Useful Post:
jbfan (11-18-2012)
Old 11-17-2012, 04:52 PM   #3
blksith0's Avatar
I also considered getting one of those socket to outlet converters and running an extension cord down from there.
Because there's a light on the ceiling, so it wouldn't look good, but it might work. However there's no ground wire on those, so I don't think it would fit.
Old 11-17-2012, 05:00 PM   #4
Average Joe/ex-Navy IC3
gregzoll's Avatar
Not good. What are you wanting to add the new outlet for? It is not that hard to do, but can be done.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 11-17-2012, 05:12 PM   #5
Has to have a ground and there's no excuse to use an extention cord to do this!!!
Is there another outlet along that wall?
Is there access below the house? Crawl space, basement?
Old 11-17-2012, 05:16 PM   #6
blksith0's Avatar
Aw, but I already bought the extension cord, and the outlet, and a saw.
There's not really another outlet close by, and no basement.
Maybe I should just call an electrician.
Old 11-17-2012, 05:28 PM   #7
Well in that case, go ahead and give it the old college try
toastandjam is offline   Reply With Quote
Old 11-17-2012, 06:06 PM   #8
Pure Genius
I smell a troll.
Dierte is offline   Reply With Quote
The Following 5 Users Say Thank You to Dierte For This Useful Post:
gregzoll (11-17-2012), jbfan (11-18-2012), jrclen (11-17-2012), rjniles (11-17-2012), Techy (11-17-2012)
Old 11-17-2012, 07:56 PM   #9
Originally Posted by Dierte View Post
I smell a troll.
Ya think?
parman is offline   Reply With Quote
Old 11-17-2012, 10:16 PM   #10
blksith0's Avatar
Talking
Well I'm sorry.
But if I called an electrician, how would he go about adding an outlet to the the wall? Any guides or tutorials anyone would recommend?
Old 11-17-2012, 10:21 PM   #11
He would use real romex wiring and just tap off of another outlet in most cases. And run the wires through the walls.
Old 11-18-2012, 01:52 AM   #12
blksith0's Avatar
Thanks, would tapping off another outlet be really difficult if the other outlet is about 12 feet away? I'm not sure how I would get the wires to go all the way to the other side there.
What would you do if there were no other outlets to use?
Old 11-18-2012, 07:20 AM   #13
Electrical Contractor
kbsparky's Avatar
The fact that you bought the wrong materials and will incur additional expense getting the right stuff does not make it OK to use the wrong stuff.
Well I'm sorry.
An electrician would not have and need for "guides or tutorials."
Call the electrician. You're in way over your head on this one.
-KB
kbsparky is online now   Reply With Quote
The Following 2 Users Say Thank You to kbsparky For This Useful Post:
Jess82 (11-18-2012), Jim Port (11-18-2012)
Old 11-18-2012, 10:04 AM   #14
Call an electrician!
The purpose behind code is first and foremost, safety and that would mean getting rid of extension cords! They are the cause of many fires and to run one in the walls you might as well kiss your house goodbye now.
Jess82 is offline   Reply With Quote
Old 11-18-2012, 08:50 PM   #15
Rochsolid's Avatar
Pull a new line from your existing plug up the wall and I to your attic, and drop it down the wall to where you want your new plug. Install a cut in box for your plug and install the plug. DO NOT fish a extension cord down your wall!!! If you feel you cannot complete this job safely and to code, then my advice is to hire an electrician for this. Good luck
Rochsolid is offline   Reply With Quote
The Following 2 Users Say Thank You to Rochsolid For This Useful Post:
blksith0 (11-19-2012), Jess82 (11-19-2012)
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 05:14 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 10:13 PM
Switched Outlet Issue mjm Electrical 11 01-23-2011 08:41 AM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 04:36 PM
