-   -   How to add another box? (http://www.diychatroom.com/f18/how-add-another-box-38020/)
detroti_fan 02-10-2009 12:02 AM
I replaced an electric stove with a gas one, so now i have an open breaker. It is a 220v 40 amp pushmatic breaker. I am installing a new saltwater aquarium and need some outlets for it. Can i run the 220v 40A circuit to a smaller new breaker box just for the tank and then install 4 10amp individual breakers in the new box? What i want is to be able to install 10 total outlets but split onto 2 different breakers so if one trips i still have some pumps running. I figured that would leave me 2 open ones for later use. I want to install gfci outlets because this is for a fish tank, but i don't want all 5 to go out if only 1 outlet trips, so do i need to wire them in parallel?
My electrical knowledge comes from the auto industry, so don't have the skills to do this on my own but i have some help form my dad who has done home wiring before. I just want some input from you guys so i know what i'm asking him to do.
I would also appreciate any input on brands of boxes or any other recomendation you would like to add.
One last thing, if adding this second box is ok, how much should i expect to pay if i have an electrician do the work? The new box will be right next to the existing one and outlets will be with 10 feet of the box, no fllors or walls to go through, just along the wall.
http://i85.photobucket.com/albums/k8...n/P1010053.jpg
http://i85.photobucket.com/albums/k8...n/P1010057.jpg
http://i85.photobucket.com/albums/k8...n/P1010056.jpg
jamiedolan 02-10-2009 12:26 AM
$50 to $100 for the sub panel, plus some expense for necessary items such as wire between the panels, conduit, etc.
You will have outlets on a minimum of a 15A breaker. Mind as well use 20A in my opinion. Run 12 gage wire. To do what you propose with the GFCI, you need to install a GFCI outlet for each outlet and wire them each directly.
Cuttler Hammer CH or Square D QO are the top of the line panels. SquareD QO are a residential grade panel are are ok, they are on sale this week at Menards if your in the greater Midwest area.
This will end up being a day to a day and a half of work work for a skilled person, depending on how hard it is to access the area to install the outlets, it could easily cost $1,000. If you do it yourself, plan on $200-$300 in materials and plan to invest a lot of time learning how to properly install this setup.
Jamie
Leah Frances 02-10-2009 09:10 AM
Uh, you might want to relocate your RO generating system from underneath your box. Especially if it's salt, but in general water and electricity doesn't mix.
