Housing For Steam Shower - Electrical - DIY Chatroom Home Improvement Forum
Old 01-25-2009, 02:08 PM   #1
Housing for steam shower
Our electrician has installed two 1100IC Lightolier housings labeled "suitable for damp locations". When I spoke the manufacturer they said it's not technically certified for steam use and that the completed assembly is ultimately what determines whether it can withstand the water/condensation. Is there reason to be concerned? Or can this be addressed sufficiently with a good full assembly and caulk?
steel1 is offline   Reply With Quote
Old 01-25-2009, 02:58 PM   #2
Electrician
The trim is what will determine if the fixture is suitable for use in the shower, not the housing. As long as you install a trim that is suitable for use in wet locations you're good.
EBFD6 is offline   Reply With Quote
Old 01-25-2009, 06:18 PM   #3
Backerboard under Fiberglass Shower Pan? BillyDIY Plumbing 2 12-17-2008 01:47 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
very low shower head flow rickard681 Plumbing 7 10-08-2008 06:43 AM
Another newbie building a tile shower ChadC Building & Construction 7 08-25-2008 02:58 PM
Bathroom Shower Help - PLEASE :) OTEJUNK Remodeling 5 05-09-2007 10:33 AM
