Housing For Potlights In Attic Space. - Electrical - DIY Chatroom Home Improvement Forum
Old 05-10-2010, 01:12 PM   #1
Rewards Points: 152
housing for potlights in attic space.
I want to put potlights on the main ground in the ceiling. The attic is up their with insulation, i want to buy those metal housing boxes to put around the potlight in the attic to give the clearance of insulation close to the potlight.
I just wanted to know if i have to put some kind of vapour barrier or some seal around the housing to stop the air coming into the house?
humberguy is offline   Reply With Quote
Old 05-10-2010, 02:42 PM   #2
If you are growing pot in your attic, just smoke some of it and then you will not worry about air infiltration. OhÖ Recessed lighting, I get it. Sorry I canít help.
studhauler is offline   Reply With Quote
Old 05-10-2010, 03:50 PM   #3
Sparkaholic
Rewards Points: 150
Send a message via Yahoo to sparks1up
Are you talking about recessed lighting like this?
sparks1up is offline   Reply With Quote
Old 05-10-2010, 04:56 PM   #4
Licensed electrician
Rewards Points: 1,490
Just install IC rated housings. Your area may also require the housings to be air-tight also.
Old 05-10-2010, 09:32 PM   #5
Rewards Points: 152
ok, ill look for IC pot lights. Do they have those IC pot lights that are 3 or 3.5 inches in diameter?
Also, can i use that red tape to make a vapour barrier or air tight?
Thanks for the advice anyways.
Old 05-11-2010, 11:33 AM   #6
Totally screwed together
I use spray foam in a gun (better control) to insulate around the edges. The smallest I've seen is 4", why do you want smaller?
xxPaulCPxx is offline   Reply With Quote
Old 05-11-2010, 10:11 PM   #7
Rewards Points: 152
i wanted smaller potlight diamters because the smaller ones look cosmetically nicer than the bigger ones.
Excess moisture/condensation/frost in attic Fingers General DIY Discussions 2 12-29-2009 10:38 PM
How much opening space lost to attic ladder? dweeter Carpentry 6 12-05-2009 01:54 PM
Best way to open up attic space? bpchevyguy Building & Construction 7 07-03-2008 06:19 AM
Crawl Space In Basement -- Please Help thekid Building & Construction 7 01-04-2008 08:15 PM
rats is my crawl space and in my attic this old house Pest Control 5 06-02-2007 05:48 PM
