Household Voltage Drop - Electrical - DIY Chatroom Home Improvement Forum
Old 12-10-2011, 06:09 PM   #1
household voltage drop
The outside receptacle on my front patio only reads 85 volts. The receptacle gets its power through a GFCI in the garage. The voltage in and out of the GFCI is 125. What is causing my voltage drop?
pilottcs is offline   Reply With Quote
Old 12-10-2011, 06:15 PM   #2
Rewards Points: 13,712
Loose wire, missing nutral. If the outlets are back stabed change them to under the screws.
plummen (12-10-2011)
Old 12-10-2011, 06:51 PM   #3
Or you have a very large house and it is several hundred feet from your garage to your front porch, 14 guage wire, and a high amperage load on the circuit.
Voltage drop calculator...
http://www.csgnetwork.com/voltagedropcalc.html
This wouldn't be your house by chance would it...
Billy_Bob is offline   Reply With Quote
Old 12-10-2011, 07:11 PM   #4
dmxtothemax's Avatar
Rewards Points: 5,352
Did you measure that voltage under load ?
Low voltage can be caused by loose connections (most common)
Or even a faulty cable.
But I would check all the connections first !
Even a faulty recepticule !
dmxtothemax is offline   Reply With Quote
Long Run Voltage Drop i_need_help Electrical 10 02-05-2011 10:53 AM
Low voltage box question WShawn Electrical 7 08-19-2008 06:22 AM
2 - 900w tansformers on a 15A circuit? tonyBagadonuts Electrical 19 07-20-2008 07:15 PM
Will splice cause voltage drop? JPsAlias Electrical 6 05-19-2008 07:09 PM
Voltage Drop between switch and fixtures CaptMike Electrical 1 06-24-2005 09:30 PM
