-   -   household voltage drop (http://www.diychatroom.com/f18/household-voltage-drop-126201/)
pilottcs 12-10-2011 06:09 PM
The outside receptacle on my front patio only reads 85 volts. The receptacle gets its power through a GFCI in the garage. The voltage in and out of the GFCI is 125. What is causing my voltage drop?
joecaption 12-10-2011 06:15 PM
Loose wire, missing nutral. If the outlets are back stabed change them to under the screws.
Billy_Bob 12-10-2011 06:51 PM
Or you have a very large house and it is several hundred feet from your garage to your front porch, 14 guage wire, and a high amperage load on the circuit.
Voltage drop calculator...
http://www.csgnetwork.com/voltagedropcalc.html
This wouldn't be your house by chance would it... :)
http://www.homeinteriorplan.com/wp-c...tmasLights.jpg
dmxtothemax 12-10-2011 07:11 PM
Did you measure that voltage under load ?
Low voltage can be caused by loose connections (most common)
Or even a faulty cable.
But I would check all the connections first !
Even a faulty recepticule !
