Old 07-12-2007, 09:37 PM   #1
House Wiring Help please
Hey. I am in college to become an electrician. My neighbor asked me to do come look a problem she was having so I went and looked. She had an old GFCI outside which was the first in the circuit, and the load side ran underground to her shed. In the shed is 2 receptacles, the first is by itself, the other is controlled by a switch. The whole system won't work.
Now, the old GFCI, i replaced, because the reset button was broken, and it was just too old. I disconnected the whole shed circuit, so just the GFCI was hooked up. I gave it power, and it works. I hooked up the next receptacle in the shed, nothing else, and the GFCI loses power. It doesn't trip or anything, it loses power completely. Which led me to believe it blew a fuse. Therefore the problem is probably the wire underground. So I replaced all the underground wiring. Laid out new stuff. Wired it all up. The whole circuit now. And BAM, still the same problem. What do I do? I have idea no where the problem is.
PS. When i look at the fuses, that I thought were blown, they seem fine, but I cannot tell. But at the start that WAS the problem. When I first started troubleshooting at the GFCI, it wasnt getting power because of the fuse.
Thanks for your help in advance,
FwuffyTheBunny is offline   Reply With Quote
Old 07-12-2007, 11:46 PM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Did you try a new fuse or swap out the fuse for this circuit with a known good one from another position in the panel?
Are you using a voltage tester to verify no power at the gfci and at the fuse panel branch circuit hot wire?
Stubbie
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
200 Amp service really needed for a 830 sq ft house? overkill? alexz Electrical 7 11-16-2009 06:54 PM
Wiring stove outlet in old house electric-pete Electrical 23 07-06-2008 04:02 PM
Wiring in older house ? Piney Electrical 11 03-11-2007 12:56 PM
Cost of replacing old knob ant tube wiring in house bikerboy337 Electrical 3 03-26-2005 09:50 AM
