House Re-wiring -- What To Expect During Inspection - Electrical - DIY Chatroom Home Improvement Forum
Old 02-28-2013, 04:59 PM   #1
House re-wiring -- what to expect during inspection
I am wrapping up re-placing the existing wiring in a 1950's home. I got the building permit before starting, and am pretty sure that all the work is up to snuff.
However, I have never gone through an inspection with a building department before. I know for new construction, there is a rough-in inspection and then a finished inspection. Is it the same for old work? Because we are living in the house, I have been wiring in devices and fixtures as I go, because it's not very convenient to live there without them. When I call for an inspection, will I have to take all of these out of the boxes for the inspector?
Thanks, in advance, for any insight anyone can provide.
richshaffer is offline   Reply With Quote
Old 02-28-2013, 05:33 PM   #2
MarginallyQualified
Rewards Points: 2,464
...will I have to take all of these out of the boxes for the inspector?
The inspector will look for clues that whoever did the work understood what they were doing and took the time to be careful while doing that; using the correct materials and hardware in the correct way.
They'll ask you to open the panel to see how everything at that end of each wire was done... and to open one or two device boxes to look at that end.
You can also count on them using a plug in polarity and GFI tester and if your area requires AFCI protction to check for that. They'll also check the overall grounding/bonding work.
If you're concerned...
then ask a handy friend to come by and check you beforehand.
hth
The Following User Says Thank You to TarheelTerp For This Useful Post:
NJMarine (02-28-2013)
Old 02-28-2013, 06:29 PM   #3
hth
Thanks for the info. That gives me a clearer idea of what to expect.
FWIW, I've spent time at the library and online to make sure I know what all the rules are by the book, and asked for clarification on a few things when I went to get the permit. The work we have done has been very meticulous, and I'm proud of it. However, the suggestion to get someone else to double-check the p's and q's before I call an inspector is a good one.
Thanks!
-Richard
Old 02-28-2013, 06:42 PM   #4
deverson's Avatar
Rewards Points: 77
Don't be cheap with the romex staples. They don't cost that much!
deverson is offline   Reply With Quote
Replacing Duplex On House w/Aluminum Wiring Mike Moody Electrical 6 11-24-2011 12:57 PM
wiring portable generator into two house panels Rage Electrical 7 12-21-2010 05:40 PM
Correct wiring diagram for 1 story house jdm001 Electrical 63 06-24-2010 05:35 PM
Old house with a mix of new and knob and tube wiring. DaleBelcher2 Electrical 9 06-06-2010 11:09 PM
Cost of replacing old knob ant tube wiring in house bikerboy337 Electrical 3 03-26-2005 09:50 AM
