House re-wiring -- what to expect during inspection
I am wrapping up re-placing the existing wiring in a 1950's home. I got the building permit before starting, and am pretty sure that all the work is up to snuff.
However, I have never gone through an inspection with a building department before. I know for new construction, there is a rough-in inspection and then a finished inspection. Is it the same for old work? Because we are living in the house, I have been wiring in devices and fixtures as I go, because it's not very convenient to live there without them. When I call for an inspection, will I have to take all of these out of the boxes for the inspector? Thanks, in advance, for any insight anyone can provide. |
They'll ask you to open the panel to see how everything at that end of each wire was done... and to open one or two device boxes to look at that end. You can also count on them using a plug in polarity and GFI tester and if your area requires AFCI protction to check for that. They'll also check the overall grounding/bonding work. If you're concerned... then ask a handy friend to come by and check you beforehand. hth |
FWIW, I've spent time at the library and online to make sure I know what all the rules are by the book, and asked for clarification on a few things when I went to get the permit. The work we have done has been very meticulous, and I'm proud of it. However, the suggestion to get someone else to double-check the p's and q's before I call an inspector is a good one. Thanks! -Richard |
Don't be cheap with the romex staples. They don't cost that much!
| All times are GMT -4. The time now is 08:36 AM. |
