House Is Only 120? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-25-2012, 02:57 PM   #1
House is only 120?
I just got everything that I need to add a 240v sub panel, and discovered I might have a problem.
There are only 2 wires coming in from the meter.
1 goes to the nuetral bar, and the other goes to the right side of the breaker bar, but then is jumped to the left side of the breaker bar. The breakers only use the left or right side with the exception of a space in the bottom that could be a two pole breaker spot that attaches to both the left and the right.
Struggling with the fact that this house was probably built in the 20's and may only have 120.
There is no 2 pole breakers on the panel.
The dryer is a stacked 120v.
Gas everthing.
I could take a picture, but would be a pain to make it helpful(pull breakers)..
benbradford is offline   Reply With Quote
Old 08-25-2012, 06:09 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
With only 2 wires feeding the panel, you do have a 120v service.
Besides the subpanel, were you needing to add a 240 load?
jbfan is online now   Reply With Quote
Old 08-25-2012, 06:12 PM   #3
Rewards Points: 105
Sounds like you'll need a new service drop from the POCO. I'm sure they will need an inspection before they connect. I've seen dozens of these small, shotgun type houses that use strictly 120V, 60A to 100A service.
Bugman1400 is offline   Reply With Quote
Old 08-25-2012, 06:24 PM   #4
Ya, it is a 125 amp 12 circuit panel... Decided it was a 120v for sure. I guess I can't run a 240 sub panel, so my next best option is either 4 20a circuits or a subpanel that supplies 70 amps or so. Is the subpanel possible? What would the wiring theory be? I already have everything for the 240 panel. I ran a 30ft price of 6/3 wire to a new panel. Is this possible?
Old 08-25-2012, 07:01 PM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
60A @ 120V isn't a large service at all. What electric loads are existing in the home?
Old 08-25-2012, 07:36 PM   #6
No, the house is 125a 120v... As mentioned above 2 bedroom house with all gas appliances with the exception of stacked 120v dryer/washer.
Could I run 2 50a single pole breakers to each side of subpanel and mount 2 25a breakers on each side?
Old 08-25-2012, 07:48 PM   #7
k_buz's Avatar
125A is the typical rating of the panel, not usually the rating of the service. Do you have a main breaker? Does that say 125 on the handle? Is there a main breaker? What size wire is feeding the panel?
It seems quite out of the ordinary to skimp on running only 120V, but to install wire large enough to handle 125A.
Old 08-25-2012, 08:24 PM   #8
No main breaker... Huge service wire...
Old 08-25-2012, 08:41 PM   #9
k_buz's Avatar
A picture would be really helpful. Is this a house?
Old 08-25-2012, 08:48 PM   #10
Ya, house. At work now...
Old 08-25-2012, 08:52 PM   #11
Picture of wiring schematic at
http://www.homebrewtalk.com/f170/hou...y-120v-349960/
Old 08-25-2012, 08:55 PM   #12
k_buz's Avatar
The diagram doesn't show what is actually there. Unfortunately it is of no help.
Old 08-25-2012, 09:12 PM   #13
I will post pics later... Assuming 120v 120a service, how close to 100a 120v subpanel could I get with 6/3 wire?
Old 08-25-2012, 10:20 PM   #14
Rewards Points: 105
For me, since you said that there is no main breaker, I don't need to see the panel, I need to see a list of all your loads.......for the main panel and your proposed subpanels.
Old 08-25-2012, 10:29 PM   #15
3 20 amp 4 15 amp... 4 open spaces in panel. How much is the most I could send to a subpanel?
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 07:18 PM
Attaching wood fence to house TheCowGod Building & Construction 5 04-13-2012 03:57 PM
Attach ledger to vinyl sided house JamyTheBuilder Building & Construction 3 03-14-2012 02:54 PM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 10:09 PM
Moving a House 70 miles- Practical? GOTHICrevivalRULES Building & Construction 19 11-27-2008 08:58 PM
