House Main Tripping - Electrical - DIY Chatroom Home Improvement Forum
Old 09-11-2012, 12:38 AM   #1
house main tripping
installed new double oven used proper breaker,and connections. tested unit worked fine. next day main kept tripping even though oven was not in use. oven breaker did not trip. any thoughts?
delta864 is offline   Reply With Quote
Old 09-11-2012, 12:39 AM   #2
couldnt open your messege
Old 09-11-2012, 12:43 AM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,162
Main tripping? Not a good thing.
I would disconnect the oven and then see if the problem is still there.
I'm assuming you have 4 wires going to the oven? 2 120Vac lines, neut and ground....right? 50A breaker?
It's possible that something else just happened to fail after the oven install....it happens.
When in doubt, backtrack and start from the beginning.
Old 09-11-2012, 12:50 AM   #4
yes 4 wire specs called for 40 breaker ,theres a breaker in the box that someone put in ,they broke it and left it. i know this is probably not good ,but it apparntly was holding, they havent uesd the oven yet,i m suspecting the broken breaker
Old 09-11-2012, 12:54 AM   #5
actually the breaker in question controlls a pump motor for pool that being loose could explain it couldnt it. and i know all about strange elec stuff happening hahaha
Old 09-11-2012, 12:55 AM   #6
Insatiable Learner
Rewards Points: 166
Smile
Wow, that's pretty amazing
AngelArs is offline   Reply With Quote
Old 09-11-2012, 12:55 AM   #7
" Euro " electrician
frenchelectrican's Avatar
I hope that someone did not actually jam in the wrong breaker in the breaker box if so that can be very serious situation going on.
Can you tell us little more on the word broken by broken handle or what?
If you can get the oven breaker off you may be ok but I will advise that you may have to call in the electrician due this is more than a just simple repair due you mention the main breaker tripping.
Useally when the main breaker trip that useally mean something major screw up.
How big the main breaker this is ??
And can you post the photo of the breaker which someone did broke it ??
Also tell us the brand name of this panel is ??
Merci,
Marc
Last edited by frenchelectrican; 09-11-2012 at 12:57 AM. Reason: add the brandname
Old 09-11-2012, 07:11 AM   #8
custom user
Rewards Points: 150
Could a broken loose breaker in the control panel cause a problem? Seriously?
JasperST is offline   Reply With Quote
Old 09-11-2012, 07:14 AM   #9
Julius793's Avatar
Of course!!
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 09-11-2012, 07:21 AM   #10
Electrical Contractor
jbfan's Avatar
Rewards Points: 254
Call an electrician!
The Following User Says Thank You to jbfan For This Useful Post:
Billy_Bob (09-11-2012)
Old 09-11-2012, 09:54 AM   #11
Yes, call an electrician. Electric panels can do this...
Billy_Bob is offline   Reply With Quote
Main Breaker Tripping Due to Heat sinaial Electrical 4 08-13-2012 09:47 PM
Main Service Panel to 2 breaker panels - I can imagine you all rolling your eyes kalus Electrical 22 03-23-2012 03:09 AM
replumb: approved way to bring main water supply up to attic and into house? hal74 Plumbing 0 11-07-2011 09:36 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 06:42 PM
