11-12-2012, 11:24 AM
#1
House inspector says an ungrounded socket necessarily mean knob and tube?
Is this really true?
I have some ungrounded electrical sockets in my house. The house inspector says reported that means I have old know and tube wiring. And so the buyer says he wants $15,000 off the agreed upon price.
If it's not true, isn't there a way to see from the wires in the sockets, whether it is knob and tube?
In your reply could you please let me know whether you are a licensed electrician?
11-12-2012, 11:35 AM
#2
Average Joe/ex-Navy IC3
They can tell by just going to the panel and looking at the wiring entering it, poking their head in a attic or crawl space, also by the age of the home. Or as simple as just looking at the outlets.
In this market, I would take anything from a buyer and let them deal with the rewiring of the K&T.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
11-12-2012, 11:48 AM
#3
Ungrounded could mean two things. Do you have two prong receptacles or do you have three prong receptacles that test no ground? How old is your house?
You can refuse and tell them to take it as is or leave. How hard up are you to sell?
Do not PM with questions that can be asked in a forum. I will not respond.
11-12-2012, 11:49 AM
#4
Thanks for the reply but that doesn't answer my question.
The house inspector said "the fact that there is no ground means it is knob and tube wiring". He just plugged in that little ground detector to determine that.
BUT I had a prior inspector who was an actual city building inspector uncover a light switch cover plate and say that it's not knob and tube wiring.
I am trying to establish whether someone can validly say: "the fact that there is no ground means it is knob and tube wiring"
11-12-2012, 11:55 AM
#5
The fact there is no ground does not automaticly mean it's knob and tube!
As stated a simple look in the attic, outlet, or under the house should be able to tell what it is.
Knob and tube looks nothing like any other type of wiring, so any nob can look at it and know.
http://www.bing.com/images/search?q=...B0D51&first=75
The Following 3 Users Say Thank You to joecaption For This Useful Post:
11-12-2012, 11:56 AM
#6
What are the two things it could mean?
The sockets have three prongs that test with no ground.
I'm not hard up to sell but I want to deal with known facts.
11-12-2012, 12:00 PM
#7
Excellent -- thank you for answering my question. I didn't think so. Unfortunately, I don't have an attic or areas with the wiring exposed. Any other way to tell?
11-12-2012, 12:02 PM
#8
JOATMON
What it really means (based on face value of just that statement), the inspector does not know his K&T from from his a$$ hole.
The existing part of my house does not have grounded outlets......I do NOT have K&T.
Common Sense is like Deodorant. Those that need it the most don't use it.
My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
The Following 3 Users Say Thank You to ddawg16 For This Useful Post:
11-12-2012, 12:06 PM
#9
Electrical Contractor
How old is the house?
Grounding type receptacles on an ungrounded circuit are a code violation, unless protected by gfci.
Just testing the receptacle will not tell if you have knob and tube, or an old 2 wire circuit.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
11-12-2012, 12:20 PM
#10
If it was a Home Inspector, he is a idiot. I would go by what the City Inspector stated, or even get them back in and if they are willing to sign off that the electrical meets the grandfathered codes for them, then go for it, and use it to negotiate the sale.
Again, with this market, people are willing to take anything to get the sale from the buyer.
The Following User Says Thank You to gregzoll For This Useful Post:
11-12-2012, 12:23 PM
#11
Open up a outlet or even take the cover off of the breaker or fuse panel. How old is this house? As for the attic, if it is insulated, move some of the insulation and look.
As a homeowner, you should know what you house has for wiring, etc..
11-12-2012, 05:19 PM
#12
Ok what am I looking for in the outlet box or breaker panel? I'm guessing that the fact of having the black wire and white wire coming out of a single sheathing means that it is not knob and tube but that's only my guess ...
11-12-2012, 05:27 PM
#13
...just cause there is no ground wire doesn't mean it is K&T !!!! there is a ton of old 2 wire style romex out there...there are ways to make it safer..  ....how old is your home??
The Following User Says Thank You to Bobka For This Useful Post:
11-12-2012, 05:37 PM
#14
Thanks Bobka. I've since read recommendations to install GFCI outlets. Not sure on the house's age but the oldest part was once a small one bedroom house that's over 45 years in my estimation.
11-12-2012, 05:57 PM
#15
You can check with the city, they would have record when it was built, and when any remodeling happened.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
