House Grounding Wire Near/touching Gas Pipe. Safe? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-08-2014, 04:39 PM   #1
House grounding wire near/touching gas pipe. Safe?
I just purchased this house, and I was taking down some of the ceiling in the basement. The electric panel is grounded to the water pipe. The water pipe is approximately 20 feet away from the panel in the basement. The grounding wire is stapled to the joists, and runs along the main gas line. There are some spots the grounding wire touches the gas line and is very close.
I am assuming this is not safe and want to reroute the grounding wire. How far does it need to be away from the gas line? The gas line is iron/steel pipe. House was built in 1950s.
CardCoder502 is offline   Reply With Quote
Old 01-08-2014, 04:59 PM   #2
Rewards Points: 1,300
perfectly safe. The gas is on the inside of the pipe.
Curious, what makes you think this is unsafe?
danpik is offline   Reply With Quote
Old 01-08-2014, 05:16 PM   #3
I was not sure really. If the ground wire were to become energized, it would seek the closest path to ground/earth... right? So it would potentially discharge through the natural gas line to earth, since that exit is a quicker route then traveling the distance to the waterline entrance.
Is that right? I am just trying to learn/understand how this works. By no means am I proficie t in electric or gas work.
Old 01-08-2014, 05:40 PM   #4
Licensed electrician
Rewards Points: 1,884
The gas line should be bonded to your panel either by the EGC run in the circuit or an external bond to the pipe.
Old 01-08-2014, 05:44 PM   #5
Rewards Points: 336
Somewhere along that gas line there is likely a deliberate connection between the gas line and the grounding wire (i.e. the gas line is bonded to your house ground). Rather than think about what happens if the ground becomes energized (hint: current should flow to ground through the wire), think about what happens if the gas line becomes energized (you want it bonded to the ground wire so that this current is dissipated).
EDIT: Jim beat me to it.
JKeefe is offline   Reply With Quote
The Following User Says Thank You to JKeefe For This Useful Post:
danpik (01-08-2014)
Old 01-08-2014, 05:47 PM   #6
electricity does not chose a quicker (shorter ) route. It choses all routes. In this case it would use both paths to ground.
This is an overly simplified answer by the way.
Stick, Jim and k-buz have written several posts on this that can explain it better than I can. I understand it, just can't seem to write it down very well.
Old 01-08-2014, 07:19 PM   #7
By bonding the gas and water lines you are ensuring that they are at the same potential as other parts,of the system so they do not carry any voltage.
Old 01-08-2014, 07:56 PM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 2,128
FYI....it is impossible to ignite the gas 'inside' the gas pipe. You also need air...translation...O2. In a pure gas environment, it can't ignite.
ddawg16 is online now   Reply With Quote
Old 01-08-2014, 07:56 PM   #9
Rewards Points: 455
Were not allowed to do that around here, although, I think it's better to do it
Cletis is offline   Reply With Quote
Old 01-08-2014, 07:59 PM   #10
So what happens to the bond created by the EGC? Is that not allowed?
Old 01-08-2014, 08:20 PM   #11
Rewards Points: 455
we are only allowed to bond the egc via branch cir to device which is connected to the csst or hardpipe, but, if their is csst going to something that doesn't require power (branch cir.) we cannot bond to it. Ex. My furnace is gas and has a 120V line with egc bonded to metal of furnace hence the whole gas pipe is bonded, BUT, I cannot take a bonding jumper from main ground/neutral bar directly to gas line anymore. I think we did it til the 80's then at some point it was banned. It makes no sense at all to me but the AHJ does what they want
Old 01-08-2014, 08:40 PM   #12
Your AHJ may want to check out the gas code rules for bonding, especially concerning CSST.
stickboy1375 (01-10-2014)
Old 01-08-2014, 09:19 PM   #13
It took you longer to type your answer since you expanded on what I said. It's all good.
Old 01-09-2014, 05:50 AM   #14
Rewards Points: 774
And that shows how stupid someone is at the public utility. As noted above somewhere in there house that gas line connects to an appliance and that appliance will be grounded one way or another, furnace - fan circuit, dryer - motor circuit……………………
Know A Little is offline   Reply With Quote
Old 01-09-2014, 06:35 AM   #15
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Incoming water (usually) is bonded, thus the water heater is bonded. If it's electric, it also (should) have an EGC.
I posted in a Cletis thread.
Deep Pipe Clog - Epic Battle Digi Plumbing 37 02-02-2013 11:48 AM
GFCI vs Grounding a two wire house Joeboo25 Electrical 30 01-03-2013 02:29 PM
Cutting and gluing PVC pipe to washer steve3847 Plumbing 8 10-03-2012 08:00 AM
Is my house adequately grounded, and what does that mean? lmark103 Electrical 6 09-15-2012 01:51 PM
grounding of main panel and sub panel in older house linkysys Electrical 2 10-01-2009 04:34 PM
