House To Garage - Electrical - DIY Chatroom Home Improvement Forum
Old 03-26-2011, 02:33 PM   #1
House to Garage
Hi, I just bought a house it has an 100A Main at the house and a 100A sub panel in the garage. The wire is buried underground about a 50ft run and it is 10-3. I have a lot of wood working tool and would like to make it a shop. I was just wondering is 10-3 sufficient from panel to panel because I thought it should be 2 or 4 gauge?
fireb is offline   Reply With Quote
Old 03-26-2011, 04:28 PM   #2
Rewards Points: 320
10/3 is not enough for 100 amps. What size is the breaker for the sub-panel that is in the main panel?
teamo is offline   Reply With Quote
Old 03-26-2011, 04:50 PM   #3
Double 30A
Old 03-26-2011, 05:11 PM   #4
Civil Engineer
Rewards Points: 4,790
The breaker is correct, a 10-3 wire is capable of carrying 30 amps, 240 volts, no more. If you need more current capacity, you will need to install a larger capacity 4 wire cable, and an appropriate panel in the garage. There are dozens of threads on this forum with detailed instructions on how to make such a connection, just do a search.
Daniel Holzman is online now   Reply With Quote
Rewiring the house, garage subpanel question WillK Electrical 4 09-28-2010 10:14 PM
Cost estimate for 2600 sq ft house including garage MissRN General DIY Discussions 3 02-28-2010 04:09 PM
Conduit through garage to house. Max wires? RyanD Electrical 12 08-02-2009 05:12 PM
Fire rated drywall between garage and house...on both sides? RyanD Drywall & Plaster 7 06-29-2009 08:49 PM
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 12:17 PM
