House Fan Started Running On Its Own! - Electrical - DIY Chatroom Home Improvement Forum
Old 06-01-2010, 02:27 PM   #1
House fan started running on its own!
Hi folks,
I have a little problem in the attic at the moment.
I have both a house fan and an attic fan.
The house fan is a two speed (like 36") belt driven fan with an on/off and High/low switch (All with three wires) and the Attic Fan is thermostatically controlled and it has a regular switch mounted next to the thermostat that will turn off power to the attic fan. It is single speed and fed with just a hot and neutral.
The system is all fed from a single junction box with the hot going into a fire stat.
The power for the attic fan comes out of the same box and if my memory serves me....the attic fan will shut down if the house fan is on.
So...here is the deal. All of a sudden the house fan turned on..and did so by itself and seems to be running in the low position (possible slower than low - it doesn't sound quite right!)
If I turn house fan switch on and have it set for low nothing changes. If I turn it to high....it sounds very bad like the motor is getting heavily loaded.
If I Kill the attic fan with the kill switch or otherwise disconnect it, the House fan will work normally.
I have a call out to friend who is an electrician and I plan to get up there tonight to try to create a schematic...but can anyone give me a tip.
Keith
Kamishki is offline   Reply With Quote
Old 06-01-2010, 10:17 PM   #2
Originally Posted by Kamishki View Post
Hi folks,
Keith
My first hunch would be that it may be a problem with the neutral.
At least that's what I would look at first.
Old 06-01-2010, 10:57 PM   #3
Master Electrician
Rewards Points: 3,782
On what basis would you decide this?
brric is online now   Reply With Quote
Old 06-01-2010, 11:13 PM   #4
A hunch!
Old 06-02-2010, 06:44 PM   #5
Master Electrician
sounds more like the motors not getting the required voltage to me. sounds like it's trying to run but the juice just isn't there. throw a test on the power at each fan with the switches on and see what you get. There's obviously some sort of interlock between the two fans if one shuts down when the other is running. start with the attic fan and it's controls...seems to be the most likely culprit.
andrew79 is offline   Reply With Quote
Tags
attic fan , whole house fan
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 08:18 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
DIY rewire the whole house... brons2 Electrical 20 02-21-2010 01:17 AM
200 Amp service really needed for a 830 sq ft house? overkill? alexz Electrical 7 11-16-2009 06:54 PM
