Old 12-01-2009, 02:10 PM   #1
Post
house electrical problem
Hi, to all New member here. Installed a dryer vent and when cutting through wall made contact with wire that supplied power to wall outlets, now have no power to several outlets & no power to wires at first outlet. Breaker did not pop. Please help !!
mxtr is offline   Reply With Quote
Old 12-01-2009, 02:21 PM   #2
Xtreme DIY'r
You've cut a wire
You will need to open up the wall & run a new wire
Or install some junction boxes & splice in a piece if wire
If you don't feel comfortable doing this hire an electrician
Old 12-01-2009, 02:32 PM   #3
Thanks, Scuba Dave But the wire is not cut through that was the first thing I checked.
Old 12-01-2009, 02:37 PM   #4
300zx's Avatar
Post
Is there a Gfci outlet around ? You could have triped the Gfci.You could also shut all the breakers off and turn them all back on sometimes it's hard to tell when a breaker is triped.
300zx is offline   Reply With Quote
Old 12-01-2009, 02:39 PM   #5
I'm going to guess that the wire is downstream of a GFCI outlet, that the saw cut the insulation, and tripped the GFI.
If the insulation is cut, you still have to do the repair as outlined above.
pyper is offline   Reply With Quote
Old 12-01-2009, 03:23 PM   #6
There is no GFCI upstream or dwnstream but I did knick the insulation,these are great suggestions let's keep trying - thanks !
Old 12-01-2009, 04:04 PM   #7
How close is the nearest outlet?
If it isn't fastened properly perhaps when you hit the wire it shook the conductors loose. Seems like a long shot.
Old 12-01-2009, 04:05 PM   #8
Just because you didn't cut all the way threw the wire, does not mean it is not damaged.
Paelectrican is offline   Reply With Quote
Old 12-01-2009, 04:17 PM   #9
Xtreme DIY'r
Yeah...mine wasn't really a suggestion - it's what you need to do
Possible a loose conenction in a nearby outlet....but I doubt it
Look for a burn mark on the blade or wire - tho if going fast enough might not be there
Old 12-01-2009, 07:08 PM   #10
Electrical Contractor
Some breakers that trip never look tripped.
What brand of breakers do you have?
To reset the breaker, it must be turned off, then turned on.
Agreed that if the wire is damaged, it must be repaired in a safe and code compliant way.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 12-01-2009, 07:20 PM   #11
joed's Avatar
If you tripped the breaker or lost power then the wire is damaged enough that it need to be replaced. All splices must be in accessible junction boxes. You can't just repair it and bury it inside the wall.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 12-01-2009, 08:19 PM   #12
Thanks to everyone that responded, they are all very good answers. Now to carry on I did find where the insulation was caught by recip. saw it's not a very big bare spot maybe 3/8" and I can see wires, but its in a real tight spot to get to - from outside wall down thru floor into basement did check the saw blade and it did have burn marks - have two circuit breakers for basement neither one was tripped do I still have to access the wire and replace that section ( junction box) ? as you can tell I dont have much experience with electricity. Thanks again for the help!!!
Old 12-01-2009, 08:25 PM   #13
Yes you need to replace the wire. You can use a j/b if it will be accessible, if not you will have to run a new wire completely. Also you need to locate the breaker for this and shut it off, if it did not already trip!
Old 12-01-2009, 09:04 PM   #14
Learning by Doing
Leah Frances's Avatar
MXTR - a host of super-helpful and truly knowledgeable have offered you ONE option for your damaged wire. Sorry, no matter how small the damage. You HAVE GOT to fix it. Welcome, we'll be happy to help (and by 'we' I mean people who know what they're talking about).
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 12-02-2009, 12:35 PM   #15
Smile
Thank's again to suggestor's Input is appreciated I will try to find an access to wire and repair if not - looks like I'll find an electrician. Better Safe Than Sorry !!!!!!! Thanks again - Mxtr
Slight electrical current in bathroom faucet water + other unusual electrical events story Electrical 9 09-16-2009 11:28 PM
Whole house fan electrical install shalmi Electrical 3 07-01-2009 12:51 PM
House electrical wiring issue. gnidaerd General Discussion 5 06-07-2009 03:42 AM
electrical service for new house ehurlbut Electrical 4 08-20-2008 09:14 PM
Perplexing electrical problem prglor Electrical 4 05-30-2007 03:20 PM
