House Dryer 229 Circuit Big Elec. Motor - Electrical - DIY Chatroom Home Improvement Forum
Old 04-11-2011, 01:36 PM   #1
House Dryer 229 Circuit big elec. motor
Can I safely run a 5hp RPC on a household 220v dryer circuit w/ 30 AMP breaker? + It about a 60 foot run.
krrgyy is offline   Reply With Quote
Old 04-11-2011, 02:48 PM   #2
joed's Avatar
Rewards Points: 13,348
What is an RPC? What size breaker does the manual say to use?
Old 04-11-2011, 03:01 PM   #3
Rewards Points: 1,668
RPC: reciprocating particle compactor; something like a flue capacitor with moving parts I think.
bob22 is offline   Reply With Quote
Old 04-11-2011, 03:18 PM   #4
clarity
I am new here...
My RPC question refers to a Rotary Phase Converter. In my garage sits (lying on the floor) a used Stenhoj car lift...I got it for "free" haha.
To hook it up and operate it I need 3 phase power to run a 3hp 2.2 kw motor. I need to convert 220v AC single phase to 220v 3 phase. Rotarys seem to work well but do I need to run a dedicated circuit. As of now the plan is to power it with a 5hp RPC.
There is no manual ...this thing is 20 years old and "come get it as is...
Thankx
Old 04-11-2011, 05:58 PM   #5
Semi-Pro Electro-Geek
Rewards Points: 2,970
That's probably OK. At a typical efficiency of 1000VA/HP, 5HP will require about 21A at 240V. It is possible that the startup current might trip the breaker, but that's unlikely since the momentum of the rotary phase converter helps supply some of the startup energy for the load.
mpoulton is offline   Reply With Quote
Old 04-11-2011, 09:40 PM   #6
Missouri Bound's Avatar
Do you have the phase converter yet? If not, if may be cheaper to bu a single phase motor for the lift.
Old 04-11-2011, 11:43 PM   #7
" Euro " electrician
frenchelectrican's Avatar
It might be a doable but I suggest to set up a subpanel in your garage this will work alot better than try to drag the extendison cord each time you have to use the lift.
Not always the case depending on the C- face motor and frame size the smaller one it may not be big diffrence on sizewise but once you get over 3 or 5 HP then it will show the diffrence there.
The key item is the frame size between the single phase motour and triphase motour if both are same frame size it possible to swap it over with out major issues.
Merci,
Marc
Old 04-12-2011, 08:34 AM   #8
Originally Posted by 1coollift
[me]...according to Ken ....I can run this 7.5hp RPC on my 30A 220 dryer/garage circuit.....
Amazing
[Rob] "Amazing is right, even without adding a loaded motor a 7.5 hp shouldn't work on 30 amp single phase 240v."
Rob
This is the same topic on Practical Machinist. What does Rob mean..."shouldn't work"...any help here. Thanks
Old 04-12-2011, 09:24 PM   #9
Amazing
Rob
7.5 HP motour ?? on 30 amp circuit is not a really wise move to use it and one thing I can garnautee you that it will blow the fuse or trip the breaker before you get the motour loaded up.
The 7.5 HP motour typically used on 50 amp circuit to withstand the starting surge and there is few extempts on the OCPD on this one and it will be in Art 430 et 440 they cover it very well.
Merci,
Marc
Old 02-03-2012, 01:06 PM   #10
Happy ending
Success-
Dedicated 50A panel in garage fed by #6 wire.
Elimia 10hp RPC.
Works like a charm.
Thanks Ken @ Elimia.
Re-route dryer electric cable Stu27 Electrical 10 09-06-2010 08:21 PM
trying to get educated about house wiring ChrisJJ Electrical 7 08-08-2010 02:23 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
HELP ! trouble putting belt back on Kenmore elec. dryer ! jays_gyrl1027 Appliances 2 09-17-2008 06:16 PM
dryer & stove sharing circuit? teamSpatula Electrical 9 09-16-2008 02:59 PM
