Houdini Electricity-Voltmeter Reading:30??? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-11-2011, 08:28 AM   #1
Setting: 60 yr old house with conduit/bx in Chic suburbs. Man agrees to wife's request to move a light fixture one foot. Man has owned the house for 20 years, done many projects (including electrical). Turning 50 on this very day, the man decides "today is the day" and slides the screwdriver into the first slot...
Problem: After taking down old light, I discovered a 30v reading at the ceiling with switch in off position. Disconnected wire from switch and it still read 30. Measured newly disconnected end out of switch box - 30. (BTW-testing to box.)
My Hypothesis: This is either the long-dead magician come back to taunt this DIY-er or (more likely) I don't have the ends of the wire I thought I did or ...?
Question: Is there anything else that would cause this reading? The hot wire is free on both ends (or so I think) but it still reads 30v.
Mark9 is offline   Reply With Quote
Old 06-11-2011, 08:41 AM   #2
Electrical Contractor
kbsparky's Avatar
Inductive or phantom voltage. You are measuring the "voltage" on a disconnected wire that is in close proximity to another wire that is still connected. The characteristics of A/C would produce those kind of false positive readings.
Try using a solenoid loaded tester, or put a load on the wire and measure again.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
tyuiop (06-11-2011)
Tags
low voltage
Questions about providing electricity to an outbuilding drichards Electrical 4 12-11-2010 11:07 AM
How does electricity meter calculate kwh? deerhunter Off Topic 18 09-06-2010 08:26 AM
No electricity in half the room (somewhat complicated) jimbob8690 Electrical 1 07-13-2010 03:23 PM
Is there a way to tell what's using the electricity from panel? Piedmont Electrical 9 02-12-2009 12:04 AM
Electricity to barn Sherdogmma2010 Electrical 12 09-05-2008 06:29 PM
