Hot Wire Styrofoam Cutter - Electrical - DIY Chatroom Home Improvement Forum
Old 01-14-2012, 03:32 PM   #1
hot wire styrofoam cutter
yes I have a wired door chime Transformer and its got one green wire on one side one black wire and one white wire on one side and two black wires on the other side what side does the plug go on
kcooper7 is offline   Reply With Quote
Old 01-14-2012, 04:02 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,970
Huh???
The Following User Says Thank You to Speedy Petey For This Useful Post:
gregzoll (01-15-2012)
Old 01-14-2012, 04:05 PM   #3
Rewards Points: 13,968
And how did you come up with this idea?
Old 01-14-2012, 04:19 PM   #4
jproffer's Avatar
Rewards Points: 716
You do know that any wire you can touch with power going through it, isn't going to get hot......right??
And only certain types of wire will get THAT hot anyway.
What's this have to do with a doorbell?
OR
What does your doorbell have to do with a hot wire cutter?
jproffer is offline   Reply With Quote
Old 01-14-2012, 09:54 PM   #5
Rewards Points: 410
Really doubt if you have enough transformer there.
I made a rudimentary one once with a good sized battery charger, nichrome wire and pcv frame.
It worked but the noxious fumes were to much.
High Gear is offline   Reply With Quote
Old 01-14-2012, 10:07 PM   #6
joed's Avatar
Rewards Points: 13,308
Variac works best for this. You can adjust the voltage while watching the wires colour.
Old 01-14-2012, 10:22 PM   #7
Rewards Points: 674
You should be able to find a hot wire styrofoam cutter at a craft store. I used it to cut 2" foam and it was VERY slow going. Not worth the bother IMO.
gma2rjc is offline   Reply With Quote
Old 01-15-2012, 07:07 AM   #8
Rewards Points: 1,216
Sounds crazy but an electric carving knife works well. Try it.
COLDIRON is offline   Reply With Quote
The Following 2 Users Say Thank You to COLDIRON For This Useful Post:
gregzoll (01-15-2012), oh'mike (01-15-2012)
Old 01-15-2012, 07:12 AM   #9
DIY staff
Rewards Points: 7,174
We used those for cutting foam rubber insulation when wrapping heated pipes.
Worked well----
oh'mike is online now   Reply With Quote
COLDIRON (01-15-2012)
Old 01-15-2012, 09:24 AM   #10
joed's Avatar
If you are making model airplane wings it's pretty hard to find a knife that is 2 or3 feet long.
Old 01-15-2012, 12:59 PM   #11
Registered User
Rewards Points: 526
I removed some of your posts.
Please keep in mind the first forum rule: Users shall treat each other with respect at all times on DIYChatroom.com. Name calling, personal attacks, or other inappropriate behavior will not be allowed and may cause your account to be banned."
These are found at the bottom right-hand corner of every page, thank you, Gary. Carry on.....
Old 01-15-2012, 02:04 PM   #12
Rewards Points: 6,652
Am I missing something here.
ceiling fan wicked97 Electrical 4 08-21-2011 08:12 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 01:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
