The Hot White - Reidentify (change Color) - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-24-2008, 08:26 AM   #16
the Musigician
DangerMouse's Avatar
now THAT'S funny!
DM
Old 10-24-2008, 10:59 AM   #17
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Originally Posted by beenthere View Post
Are all DIYers competent electricians?
What is common sense to a tradesmen, may not make sense to an inexperienced person.
If I understand correctly, what it comes down to is that that white wire needs to be re identified to be code legal in most areas, because it is actually being used as a hot.
I had 8 wires in a box, I was able to figure it out, but it was a bit confusing with all of the wires hanging there, and I thought, if this white wire is getting tied into hot for the switch, then why isn't it re identified? It seems the answer is that it should have been.
Jamie
jamiedolan is offline   Reply With Quote
Old 10-24-2008, 11:06 AM   #18
the Musigician
agreed!
DM
Old 10-24-2008, 03:50 PM   #19
In residential wiring , roamex would be like a cord where you can't choose the color , so you should mark the white to identify it as hot in that situation . Sadly enough , few pros do .
electro is offline   Reply With Quote
White Pine Hard-Wood floors? MrShadetree0222 Flooring 9 11-04-2008 09:24 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
ceiling white - crown molding color question remodelingagain Interior Decorating 3 06-06-2008 02:16 PM
Trim color and interior doors..white or off white? kristinnsmith Interior Decorating 3 04-22-2008 06:48 PM
change color of flooring and other wood finishing, possible? KUIPORNG Remodeling 3 07-20-2006 07:54 PM
