#1 |
hot water timer
My hot water timer is making a noise continously (at least every time I check it). Almost every second. Is this something to be woried about, or does it need replaced?
Thanks |
#2 |
Sparrky
hot water timer
much more information would be useful . . ." Hot Water Timer" . . .havent heard this one before . . ..do you mean thermostat?
? type of timer if not the thermostat ? . .voltage of the timer ?. mechanical timeclock type with conrtacts ? |
#3 |
hot water timer
Most all water heater timers have a very small motor turning continously, as inside a watch. If it is a continous hum, it is just the motor running. As you are aware the dial turns. This is accomplished by the small motor turning inside.
| Display Modes | |
| Water Heater Timer | capt2 | Plumbing | 4 | 01-16-2008 07:04 PM |
| Help! Water Problem no one can solve! | Goonky | Plumbing | 4 | 12-24-2007 10:03 AM |
| Water Heater Timer | piecekeeper | Electrical | 3 | 07-19-2007 07:12 PM |
| Periodic release from (I think) the T&P valve on the water heater | alexz | Plumbing | 3 | 08-15-2006 11:31 AM |
| Timer for hot water heater | toolmanwannabe | Plumbing | 6 | 09-23-2005 04:45 PM |
