Hot Water Tank - Electrical - DIY Chatroom Home Improvement Forum
Old 08-26-2012, 10:02 PM   #1
hot water tank
what seize of breaker for hot water tank
hank2008 is offline   Reply With Quote
Old 08-26-2012, 10:04 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Electric water heater? gas? oil? specs? anything?
Old 08-26-2012, 10:13 PM   #3
" Euro " electrician
frenchelectrican's Avatar
That is pretty wide answer there.
We need more details here.
Tank size ( how many gallon/liter tank )
Heating element wattage ( for tank and tankless verison )
Supply voltage.
If not using electrique heating element then if have gaz power vent or oil fired or wood boiler water pump.
So more question you can answer the more acture answer we can posted.
Merci,
Marc
Old 08-27-2012, 07:01 AM   #4
Licensed electrician
Rewards Points: 1,766
There should be a dataplate on the WH. This will tell you the electrical requirements.
Old 08-27-2012, 07:17 AM   #5
Rewards Points: 6,652
1 million Giga-Amps.
Old 08-27-2012, 11:18 AM   #6
Rewards Points: 1,538
Very rarely will you find an electric tank type water heater for home use requiring more than 30 amps (10 gauge wiring). Only one of the two elements operates at any given time.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
how to stop drops of water at tank top receptacles? young707 Plumbing 6 08-22-2012 05:41 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
