Hot Water Pipe And Electrical Wire? - Electrical - DIY Chatroom Home Improvement Forum
Closed Thread
Old 01-17-2014, 11:36 PM   #1
Hot water pipe and electrical wire?
Hello. Since I don't have any ceiling-mounted lamps in my apartment I've decided to get the lights a little bit higher myself. Since every room in my apartment has a water pipe (which get's hot!) for heating the second floor I thought of mounting a few spotlights on them myself. I would like to have a red (or any other color (let's say this one http://www.homedepot.com/p/Workforce...3Frpp%3D96#)(I would just simply cut one side of the plug and then solder the wires to the lamps) wire just wrapped around the water pipe. And I'm just a little worried of the heat from the pipe damaging the wire. How can I be sure the heat won't damage the wire?
Thank You!
Isstatu1 is offline
Old 01-18-2014, 02:54 AM   #2
Licensed electrician
Rewards Points: 1,272
Extension cord is not to be used as a substitute for fixed wiring. Also the heat would degrade the insulation.
Jim Port is offline
jackmel (01-19-2014)
Old 01-18-2014, 08:05 AM   #3
Rewards Points: 1,294
At some point in the future you local newspaper will carry a story that includes the phrase: "the cause of the fire was determined to be electrical in nature."
danpik is offline
The Following 4 Users Say Thank You to danpik For This Useful Post:
gregzoll (01-18-2014), mpoulton (01-18-2014), Speedy Petey (01-18-2014), stickboy1375 (01-18-2014)
Old 01-18-2014, 08:16 AM   #4
Rewards Points: 20
If this is a rental apartment you need to talk with your landlord about hiring a qualified electrician.
daveb1 is offline
The Following 2 Users Say Thank You to daveb1 For This Useful Post:
danpik (01-18-2014), gregzoll (01-18-2014)
Old 01-18-2014, 10:30 AM   #5
That's why I'm asking for advice in this thread so it would be done as safely as possible...
Isstatu1 is offline
Old 01-18-2014, 10:43 AM   #6
The cord you linked too is not rated for hanging weight from. Also, any connections either soldered or wire nutted need to be inside an approved containment device. If you realy need to add lighting, go to a lighting showroom and see what they have available. You will be surprised at how many different styles of lighting there is out there
danpik is offline
Old 01-18-2014, 11:04 AM   #7
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Buy a lamp...plug it in.
k_buz is offline
The Following User Says Thank You to k_buz For This Useful Post:
Old 01-18-2014, 12:29 PM   #8
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,878
Originally Posted by k_buz View Post
buy a lamp...plug it in.
This!!
Speedy Petey is offline
Old 01-18-2014, 12:29 PM   #9
See previous reply.
Old 01-18-2014, 02:53 PM   #10
There would be no height hanging from the wire. The lights would be attached securily to the pipe. The wire would be just wrapped loosely around the pipe without any tention it.
And come on guys... I undetstand that I can go out and buy a lamp and just plug it in. But that's just not what I want...
Isstatu1 is offline
Old 01-18-2014, 03:57 PM   #11
Rewards Points: 20
But what you want cannot be done safely or legally. One must be very diligent when doing DIY in an apartment when the outcome affects your and other people's property and lives.
daveb1 is offline
The Following User Says Thank You to daveb1 For This Useful Post:
Jim Port (01-18-2014)
Old 01-18-2014, 04:04 PM   #12
Unfortunately, you are not going to get what you want here, which is for someone to tell you this is OK
danpik is offline
The Following 3 Users Say Thank You to danpik For This Useful Post:
Jim Port (01-18-2014), Speedy Petey (01-18-2014), stickboy1375 (01-18-2014)
Old 01-18-2014, 04:44 PM   #13
Rewards Points: 1,192
Move!
bobelectric is offline
Old 01-18-2014, 05:42 PM   #14
Ok. I own the appartment. And it's not located in the US. So the common US electrical laws don't apply.
Isstatu1 is offline
Old 01-18-2014, 07:00 PM   #15
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Am I the only one who smells a troll?
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline
The Following 2 Users Say Thank You to electures For This Useful Post:
bbo (01-18-2014), Code05 (01-18-2014)
Closed Thread
Tags
electricity , heat , lamps , pipe , wires
Ground Wire digitalplumber Electrical 44 05-20-2013 05:04 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
Permit For Fire Sprinklers letnes Plumbing 18 10-14-2010 06:23 PM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 10:48 AM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 07:38 AM
