Hot Water Heater Breaker???? - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 12-21-2008, 07:34 PM   #31
Originally Posted by Bigbobdallas View Post
Went and got me a new breaker and it is working great.
So the hot breaker was actually bad,
or during installing the new breaker bad connections were tightened up in which case reinstalling the old breaker would have worked, also.
All's well that ends well.
Old 12-21-2008, 08:31 PM   #32
DIYer
Went and got me a new breaker and it is working great. Thanks for all the info. By the way it had a gas hot water heater and I ran a 220 from the main and put into a small breaker box and then put a 30 amp to the new Hot Water heater. But any how it is working OK now after two days.
What size wire did you use?
Gigs is offline   Reply With Quote
Old 12-21-2008, 08:47 PM   #33
Dutch and Cheep!!
Send a message via Yahoo to old dutchman
Breaker trips
Did you check if the lower Heat tube is good. Do you have soft water,or could you have a deposit on the lower unite grounding out?
old dutchman is offline   Reply With Quote
Electric Water Heater GTSRider Plumbing 31 12-07-2008 11:30 AM
Installing a Tankless Water Heater infoiam Plumbing 4 11-10-2008 09:59 PM
Water Heater Troubles deadguydrew Plumbing 9 10-19-2008 09:30 AM
Water source from fridge from water heater? dankreboot Plumbing 11 07-12-2008 10:08 PM
"sticky" gas water heater thermostat homer12 Appliances 8 01-25-2008 04:36 PM
